OK, seems like everyone wants different levels of light output, as well as the option of flood or spot. Why not put all options into one flashlight?
Consider:
A flashlight with a LED/lens on either end, with a SPOT setup on one end and a FLOOD setup on the other end. Turn either end on/off with a pushbutton. We reserve rotating the bezel(s) for variable output - rotate full counterclockwise for max output (say, 200 lumens) and full clockwise for min output (say, 0.1 lumens) with infinite (exponential?) variability in between. Wherever you stop the bezel, that is your light output regardless of the on/off switch (e.g. - built-in physical memory). You could even utilize GITD markings to help determine expected output before you hit the on/off switch. Add to that a low-power "find-me" blinking red LED and you may have a nearly-perfect flashlight.
Power options? Anything that can be designed in. Personally, I'd prefer a 3 or 4 AA light stacked in cylindrical fashion (like short/long versions of TK40), and a version with the batteries lined up in parallel. Maybe another large version that could utilize 3-4 C/D cells for a more tactical light. And, if they could fit the electronics in, a AAA version for EDC pocket-carry. Oh yeah, and some 123/R123 versions to keep everyone happy...
Consider:
