wildstar87
- Joined
- Nov 12, 2007
- Messages
- 369
I was reading the "Making your own thermal expoxy" thread, when someone mentioned using just standard thermal compound underneath the emitter and epoxy on the sides to hold the emitter down.
It got me thinking about how CPUs are held down, then I thought... Hey why couldn't you do that with an LED? The Cree package is almost perfect for that, IMO..
You could have a Heatsink with "clip" that fit over the LED with a hole in the middle that the emitting part of the unit fit through. In addition you could make the clip have the leads for the led, so you just put the thermal paste down, set it down on the heatsink, and screw the "clip" down on top of the Cree emitter, which is automatically contacted by the leads on the clip.
This way, you get the new whizbang bin, you just unscrew the clip, pull the old led off, put the paste on the new one, screw down the clip, and bingo your off and running again. No fuss, no muss, no soldering, etc...
You could even have different clips that were designed for the different LED types, SSC, Luxeon, Edison.
It seems really doable, with someone with the right equipment.. Whaddya think?
