Hi,
Everyone has a Flashlight who he likes most, but there are may be others which have some features you would like on your favorite one
If you had the ability to mix the Gene's of your favourites Flashlights to a Super-Flashlight ... how would it look like.
I would mix them from:
And my Gene-Mix-Dream-Flashlight-Monster would have the following:
not realistic.
One cant optimize robustness an flexibility at the same time.
How would you mix your dream flashlight out of your favorite ones?
Regards
McGandolf
- Nitecore D10
- Novatac 120 E
- RA Clicky Executive
- Liteflux LF5 XT
- Lummi Raw NS
- Jetbeam I Pro Ver 2.0
- und hmmpf…
- Knurling: Novatac 120E : best grip of all, even better than the D10.
- Form: D10 : plain noble. no need to squiggle a flashlight. due to the excellent grip no need for a recessed grip.
- Button: D10 : sturdy Piston-Drive. Clickies tend to be the weakest part of a flashlight .
- Screw Thread/Windng: Lummi Raw NS: excellent - non creaky. I suppose due to the material Nickel-Silver. Didnt manage to get the smooth way to twist it with alu.
- Robustness: RA Clicky: I suppose even a tank would be able to roll over it.
- Waterresistant: RA Clicky: 66 Feet. I would rather go for 100 feet to allow diving but 66 feet good enough for outdoor usage.
- Customizing: Liteflux LF5 XT: Plenty of features: change number of modes, brightness for each mode, frequence for flashing, beacon .. and and and
- Programming: Liteflux LF5 XT: After some initials probs i am now a master of the liteflux system.:duh2: Its incredible how many commands you can pass to the flashlight with just one single button.
- Flexiblity: Obviously the Liteflux LF5 XT.
- User-Interface: Again the Liteflux LF5 XT: Double-Click for next mode and Shortcuts: Click-Press=max, Double-Click-Press=Strobe. The only thing i miss is direct accessing a mode (eg 3-Clicks= Mode 3).
- Click detection: RA Clicky: The click-detections on the liteflux is to long (0,4 sec). Its much better on the RA with (0,3 sec). Its just 0,1 sec difference but it feels much better.
- Beam Tint: From all my flashlights the Lummi Raw NS Natural has the best tint. Natural white tending to yellow
- Min Light: RA Clicky: 0,3 Lumen pre-set but you can goes down to 0,07 Lumen. Only switching off is darker :huh:
- Max Light: Jetbeam I Pro. The brightest one i have on a single AA. As usual ... the brighter the better
- Auto-Off: Novatac 120E: Swiches off after a few minutes. Every flashlight should have this as an option.
- Save-Batterie: Novatac 120E: Reduces output if runs out battery. This way you are not in the dark from one second to the next.
- Beam The best Beam has my Olight T25.
- Cell-Voltage Indicator: Liteflux LF5XT: Great Idea to flash the voltage of your cell.
- Focus: Led Lenser P7: ok, not a great flashlight, but to be able to give it a bit more spot .. or spill would be great. Indoors for example i dont need spot at all.
- crenelated bezel: Like on my Olight M30: on head and tail. But for casual wear it would be good to be able to remove them.
- Cells: AA Batterien and ability to work with a wide voltage range, eg to use 14500er
- Extension tube for extending run-time.
- Direct access to certain mode from off: 3-clicks = Mode 3
- Withstanding Sea Water. Rain is fine but salt water is much tougher in the long run.
- Ability to set lower and upper output on a beacon flash. Great for biking if you want to use your flashlight as a rear light. I want to have the light pulsating instead of on/off/on ...
- flashing the remaining runtime at the current brightness level (1 flash every 10 minutes, 4 flash= still have 40 minutes)
- Teaser Mode. The flashlight has already a cell, elektronic and sturdy tube. Its not intended for going to war, but it would be fine to get rid of a aggresive dog.
Regards
McGandolf
