I just assembled Lambda's Illuminator SMD with a 1W HD Luxeon today. Before I applied epoxy to the pill I connected a DMM, the new and old pills and some batteries in series to see how much current they would draw from the battery. Below were the results;
Illuminator SMD + 1W HD Luxeon:
1 Panasonic CR123, 2.95V - few used (no load) -------------- 1.5A (app.)
2 GP Ultra Alkaline, 2.85V - some used (no load) ------------- 1.43A (app)
2 Eveready Super Heavy Duty, 2.75V - drained (no load) ----- 0.5A (app.)
ILL Pill + 1W LD Luxeon:
(Same batteries as above)
1 Panasonic CR123, 2.95V (no load) --------------- 1.18A (app.)
2 GP Ultra Alkaline, 2.85V (no load) ---------------- 1.10A (app)
2 Eveready Super Heavy Duty, 2.75V (no load) ----- 0.42A (app.)
The Illuminator SMD was burning hot in the first and second sets of battery while the ILL Pill was just slightly warm. The ILL Pill could be same hot if using fresh batteries. All readings were only approximate due to the bad contact of the DMM probe and dropped rapidly as the power consumed.
My questions are:
- Is the performance of my assemble typical to other ILL SMD/ILL Pill?
- Is the circuit current regulated or voltage regulated?
- If the ILL SMD draws 1.5A (Iin) from 2 AA fresh batteries, how much current (Iout) is it feeding the LED?
- Is the 1W LED overdriven?
- If it is overdriven, can I do some minimum mod to limit the current?
- If the inductor is not saturated (I can't figure whether the heat comes from the LED only or also from the inductor), can the pill drive a 3W Luxeon (3V x 1.5A x 75% eff.)?
I know these pills are of very simple circuit due to the low cost, but I still don't want the Luxeon burnt. And if the efficiency is acceptable, it would be a low cost 3W driver. Any advice?
My questions are:
