I\'m becoming a mad scientist
So this all started when I thought I could take a Luxeon/O assembly, and extract the bare emitter from it. *cough* wrong. All I ended up doing was popping the lens and leads assembly off the alum pedistal that the Luxeon die lives on.
At that point, I figured I'd killed a blue-green Luxeon, and blown $15. Just in playing around, I touched a couple of wires directly to the die, and *flash!* blue-green light!
So it's Friday night, and I'm pretty bored. I figure I would get the most fun out of this now-unusable (but still functional) cyan luxeon.
I decided to see how much current I can push through this little beast. I also figure to use the best cooling possible: water!
So I immersed the wounded luxeon in some tap water, and grabbed a couple of needles (to make the connection)
This happened:
That's pushing 2A through it.
The water was boiling directly from the die.
It is insanely bright
Something wierd is happening though, there was some residue left floating in the water, and the luxeon die is slightly discolored. Wonder if the LED substrate is boiling away or something.
Igor! Get my electrodes!
This happened:
