I'm going to change the LED of an ITP SA1 and I need some help
LiuChuan
Jiangsu,China
I'm looking forward to replace the xp-e r2 on my SA1 with a xp-g r5. Is that ok with it? Could anyone tell me what is the current of SA1 on high?
Hello liuChuan. I have the SA2 and it is 1.5 volt. I will try and find the current for you later unless you mean voltage. Also, I thought the SA1/SA2 already have XP-G. I will double check for you. I have to leave so it will be later. Hope I can help you. Good luck.
Keith
Hello liuChuan. I have the SA2 and it is 1.5 volt. I will try and find the current for you later unless you mean voltage. Also, I thought the SA1/SA2 already have XP-G. I will double check for you. I have to leave so it will be later. Hope I can help you. Good luck.Keith
Finally I got a reply! Thank you so much. I believe there are two versions of each of these lights——XPE R2 version and XPG R5 version. I didn't notice that when I bought it. But after some close look yesterday I found mine has an xpe on it.
