I haven't been here for many years... probably around 10 years. I currently own a handful of lights, the most notable one is my Klarus XT11. (tactical)
I LOVE this light... but I've been going on "adventure walks" with my 15 year old, and he's taken it over. So naturally, I need an upgrade.
I really like my Klarus a lot... and I'm leaning towards going with Klarus again. But I'm not sure which one to choose...
and I'm also open to input if there's some other brand similar featured, sized & weight... but brighter than my XT11.
I'm also happy to go the 18650 route if needed. (I have several backups)
Ideally, it would have better / longer throw than my Klarus XT11... and similar beam width at least. (I was leaving the scene around when LED's were just incoming... so not sure if there are some more high powererd LED's.)
and while I do like the tactical mode of my XT11... it would be nice to have a "start at the lower end" option... as opposed to "start with full brightness/emergency". (but I can do that too... would be nice to have both - which I think some of the new Klarus's may be able to do?)
Also... the size is great... The XT11 is just above 5 & 1/2 inches. A little bigger is fine... but I don't want to go over 7 inches.
Thank you for your input... I'm looking forward to hearing what you experts have to say.
Thank you! -- Jason
PS - My "Recommendation Checklist" is below.
Thank you! -- Jason
==================Flashlight Recommendation Checklist================
____I would like to purchase the light in person from a brick and mortar store. I am located in ______________.
__X__This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest!
____I don't know yet
____Up to $25.
____Up to $50.
__X__Up to $100.
__X__Up to $200.
__X__Up to $300.
__X__Essentially unlimited.
3) Format:
____I am not sure, please help me decide.
__X__I want a flashlight (hand held/self contained).
____I want a self-contained headlamp.
____I want a headlamp with an external pack/power source.
____I want a mounted light (typically for a bicycle or vehicle)
____I want a lantern/area light.
____I want a portable spotlight (it may have an external power source).
____Other ____________________________________________
4) Size:
____MICRO - Keychain size.
____TINY - Every day carry (2-4 inches).
__X__SMALL - Every day carry (4-7 inches).
____MEDIUM - Holster/belt ring carry. (>7 inches)
____LARGE - Big enough to need its own travel case.
____I don't know/I don't care.
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness)
__X__I don't know.
6) Manufacturer:
__X__I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____I would like a light from a specialty manufacturer (Possibly limited run/Custom).
____I am interested in assembling my own components. (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source).
____I intend to use "Primary"/Disposable Alkaline batteries based on the usual AAA/AA/C/D sized cells common to most stores.
____I intend to use "Primary"/Disposable Lithium batteries based on the usual AAA/AA/C/D and CR123 sized cells common to most stores (often a cold weather or long storage choice).
____I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
__X__I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
__X__I want a light with an integrated rechargeable battery pack.
____I don't know/I need more information on power sources.
____I want a light that plugs directly into the wall (literally with prongs built into the light)
____I want a light that has a recharging adapter (your typical "wall wart")
____I want a light that snaps into a cradle (usually mounted on a wall)
____I want a separate/stand-alone charger (this involves removing the batteries to charge)
__X__I don't care
____I want to navigate a dark room or read a map (1-10 lumens).
____I want an indoor "blackout" light (15-50 lumens)
____I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
__X__I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
__X__I want search and rescue type illumination (800+ lumens).
__X__SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
____All Flood: I am doing "arms length" tasks like reading and campsite cooking.
____Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
____Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
__X__Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
__X__Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
____Turbohead: I want a far-distance projector with a sharply focused spot of light and minimal or zero side-spill. Good for extreme distance and impressing your friends.
____Less than 1 yard/meter (reading, other close work)
__X__Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
__X__5-20 yards/meters (check out a noise in the backyard)
__X__30-50 yards/meters (I have a big backyard)
__X__50-150 yards/meters (I live in a very rural area/farm with wide open spaces)
__?__150+ yards (I am searching from a helicopter)
__X__Up to 30 minutes (I want the brightest [and potentially smallest] light for brief periods)
__X__30-60 minutes (I have plenty of batteries just ready to be changed)
____90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
____Not Important (A "night-stand" light).
__X__Very Important (Camping, Backpacking, Car Glove-box).
__X__Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't know.
____Any size switch will do.
____I need a BIG switch (I'll be using gloves or have very large hands or coordination issues).
____I want a forward clicky (Helpful for momentary activation and signaling).
__X__I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
__X__I want a tail mounted switch (found on the majority of today's high end lights).
____I want a remote switch (usually found on high-end bicycle headlights)
____I don't care.
__X__I don't know.
____A simple on-off with only one output level is fine for me.
__X__I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
__X__I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
__X__ (a "nice to have" - I want a strobe mode. (Oscillating pattern to confuse/blind aka "Police Mode")
____I want SOS mode. (blinks in ...---... emergency pattern)
____I want a beacon mode. (Regular flashes at full power to show location.)
____I don't care.
____I don't know.
14)Material/Finish/Coating
__X__Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
____Stainless steel (durable, but much heavier than aluminum)
__X__Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
____I don't care.
__X__I don't know.
15) Water resistance
____None needed
__X__IPX4 (Splash resistant)
____IPX7 (Waterproof to 1 meter/30min)
____IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
__X__In house (temperature/climate controlled environment)
____Emergency kit (long standby periods)
____Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
____Other_____________________________________________
__?__"Hybrid" light (bright incandescent combined with long running LEDs)
__X__Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
__X__Crenulated bezel (not a deal breaker - a nice to have)
____Non-sparking, Intrinsically Safe (IS) for use in explosive environments
