IMALENT UT90 Predator FLASHLIGHT Introduce video
imalent
Well-known member
Manufacturer
Shenzhen
IMALENT UT90 Predator flashlight is a dual-switch LED flashlight that delivers a beam distance of 1308 meters. The flashlight has an integrated 8000mAh (2pcs 4000mAh 21700 Li-ion batteries) rechargeable battery pack. The Predator delivers a maximum output of 4800 lumens with American Luminus SBT-90 2nd LED. It has versatile tail switch, functioning as a tail switch, charging port and connection port for a magnetic remote pressure switch. The Predator can also be controlled from the side switch. With high performance and easy operation, the Predator is suitable for a multitude of outdoor activities. With a bezel diameter of 66mm, a high capacity battery pack, convenient charging system and easy operation, the Predator is the best illumination tool for hunting or search and rescue.
Learn more :https://www.imalentstore.com/products/imalent-ut90-predator-flashlight
By the way, I would like to remind you that the IMALENT Christmas event will be held on December 23-26
Learn more : https://www.imalentstore.com/blogs/news/2020-imalent-flashlight-christmas-event
