The same 2.3Ah Duracells discharged and charged at 2A with a small fan attached to the bottom of the unit forcing air through the slots near the metal folding stand. Inputs, time, temperature, capacity with a 500ma discharge rate and capacity with a 500ma discharge rate of a 16 hr break-in.
Slot#1= 2106mAh, 71 min, 127.3F, 1969mAh, 2001mAh
Slot#2= 2050mAh, 69 min, 113.2F, 1969mAh, 2249mAh
Slot#3= 2079mAh, 70 min, 113.2F, 2013mAh, 2276mAh
Slot#4= 2050mAh, 68 min, 106.2F, 2018mAh, 2242mAh
The Slot#1 cell has a bit higher impedance, not sure if that accounts for the higher temperature.
EDIT: Added break-in capacity with a 500ma discharge rate. Slot#1 has the higher impedance reading cell.
