Hi;
I dont know if anyone can help, but i figured i'd put it out there anyway.
I've got a Golf Mk5 GT Sport ( Diesel vers. of GTI sort of.. ) and want to improve the low beam lights without having to resort to crappy aftermarket HID kits.
At the moment, lo and hi run Phillips CrystalVision 4300k color temp globes. The color from the driver seat is a really clear white light, albeit seemingly reduced slightly over the std globe output. You also tend to look a bit of a wally during daytime, because the reflectors look blue to oncoming drivers. Now i've seen these Phillips Xtremevision 100% + globes and was wondering how they arrive at a 100% increase in light over the standard globe without resorting to increased wattage?
The Golf, and a lot of other cars too, i suppose, run something called CANBUS, which basically means no mods to existing equipment without a lot of heartache and pain!
The standard headlight wiring is pathetically thin ( at least leading to the connector immediately on the back of the globe ) and i was curious to know if anyone has had experience with running relay's and a decent current to the globe, without sending the car's computer haywire? And if so, how did you do it?
The auto sparkies around here dont want to know, as soon as you mention the " C " word!!
What i'm basically after is an increase in light output, mainly on low, without blinding others and not destroying my car as well.
I apologize to the moderators and forum if this post is out of bounds.
Many thanks;
Mike.
Many thanks;
Mike.
