I carry my modded FF1 with me everywhere I go. I love this little light.
It has since stopped working on low and I've replaced the 2 stage switch now several times to no avail.
Here I am just about heading off the the shot show and my precious FF1 is not working up to speed.
Kinda bummed and pissed I decided to investigate this and here's what I did to get back the functionality.
First off, the copper head oxidizes pretty fast and I found that is making a poor connection with the sandwich module. To remidy this I bought the plugNplay Nickel Anodizer at Caswell plating caswell Plating and was able to electo plate the inner ledge where the sandwich makes contact. In addition to that I ended up chopping off a AA contact spring and after some contortion was able to solder that onto the two stage switch as shown below in the picture.
Since this particular mod the spring is actually higher than needed I decided to take advantage of the arbitrary cut length and remove the solder blob and replace it with a solid silver ring as shown in the photo below.
You can get the silver rings at most online jewelry places or here's a link to artbeads.com silver jump rings artbeads.com solid silver jump rings.
I also cut some poron foam washer to prevent battery rattle as shown in the photo.
I also ended up cleaning the gunk off the top of the module. After I completed all these tasks the light now works flawless and is back into near pristine condition.
I hope you enjoyed my findings.
Wayne
Wayne
