StarHalo
Now i find out if your IMR cells hit 140 Deg F they start to fail,(60C) over 150 they CAN burst and leak toxic chemicals out and destroy your light.
What battery type can withstand 140+ F degrees?
Help Support Candle Power Flashlight Forum
Can you cite a source for this, or are you just repeating something a guy told a friend of your sister's boyfriend at 31 Flavors last night?
Nice link; is that what's under AW's red label, or are his from a different mfr.?
The cells AW is using are probably not made by Emoli. In fact, AWs cells test out with higher capacity than the Emoli brand, based on LuxLuthor's testing. It also wouldn't make much sense to have Molicel (in canada) make cells for someone who has contacts in asia.
ed the P60 bulb. Guess it can't handle 2 x 16340.😳 Luckily, the IMR-9 from LF is on the way. The 6P got here yesterday, I immediatelyed the P60 bulb. Guess it can't handle 2 x 16340.😳 Luckily, the IMR-9 from LF is on the way.
I would like to get the FiveMega module with some bulbs, but I can't figure out which ones to get for 2 x IMR 16340 in a 6P. Can someone suggest which bulbs of his to get, or any others that are 1.5 (I think I have the size right) that would work with this combination?
Search for Fivemega's threads. Click on his user name and go to statistics and click on threads. You will find his selling threads. Saying this to encourage you to look for info on CPF.
Bill
I know Bill want's you to look, but I can't help myself! For a 6P and 2x IMR16340 and a FM D26 bi pin socket, you can't do any better than a FM 1794 bulb. The only other thing that might have more output is the just released IMR-9 from Lumens Factory (where the author of this thread is from!).
The reason I say might, is that I haven't seen any reviews of it yet.
