kaichu dento
If dat2xip's driver would work and you're willing to go with AA size, then you'd be in business with a 14500...
Help Support Candle Power Flashlight Forum
That would be my preference too, but I just thought of at least mentioning it since I couldn't remember if that too was one of your requirements.I am not sure exactly what you intend...but I want to use a single AA not rechargable numbered lithiums.
I have never heard someone say "darn I wish my light had 5 levels, 3 strobes, an SOS and a disco ball" but you hear the opposite often.
I once again misunderstood. If the LX2 turns on and off by twist it is not what I want.
I want on and off by forward clicky (with momentary capability) and high and low modes being chosen by a twist (either of tailcap or head)
I still don't understand if some of the above options will work for that because for every person that says it will someone else comes along and says it works differently.
I don;t have the skills or knowledge to try this...but it seems a single stage light with a resistor that is activated when twisting would work to reduce the level right? I understand it changes tint and isn't perfect but for super low light I don't care.
ztm,
If you can piece together someone to figure out your LED head and tail-cap issue on an E2E, I can take care of the easy part in an elegant fashion. A 2xCR123>1xAA machined delrin sleeve and spacer combo adapter with brass contacts; no problem. (rather than rolled up paper and a wad of aluminum foil right?)
Eric
ztm,
Eric
For anyone thats still interested...
Just tried a 10ohm resistor with a Deree XRE 0.9-4.2v dropin in a DBS and it works. Gets about 1-3lm max, I'll have to do a runtime test later. Regarding the tailcap mod: I tried unsuccessfully to solder a 150ohm resistor to another tailcap which shall remain nameless and had absolutely no luck. I'll leave it to someone more skilled with a soldering iron.
