Incan “build” for 2022?
hamhanded
PNW
Like vicv said; Mag 3C with FM G4 socket, KD aluminium reflector & glass lens. Phillips 20 or 30W G4 halogen. Run that on 2x 21700s & with an NTC in the tailcap to prevent the bulbs from blowing on full batteries (I learned that the hard way from members here). You can also use a 10W for more modest (but still bright) output & better runtime. Very practical setup with long throw.
With 7388 20W
Where do I find myself the NTC (is that soft start?)
alpg88
my last hotwire build, was 90 Watt halogen osram 64558 overdriven with 5 cells, (close to 200w) in a maglite with 2.5in FM thromaster, after that every other hotwire looks lame.
alpg88
yes, my mistake, 64458.
3-4 hours according to destructive tests, but battery runtime is about 10-15min, but since It has almost 0 practical purpose, i run it very rarely, i have not blown a bulb yet,
alpg88
Not needed, you can comfortably hold it about 4-5 inches away from the head, it does not run long enough to heat up more. but you can feel the heat at upto 10 feet in front of it.
alpg88
digikey, mouser sell those, they call them inrush current limiter, i use one in my mag 85
