biker1
I need some help explaining what happened in the following situation >>
I have an IncenDio V3, and used a new, freshly charged AW R123A cell (4.11V) right off the Pila IBC.
I wanted to see how long the V3 would stay lit on High, regarding until it dimmed and/or eventually shut off..
I held the V3 approx. 25 minutes (may have been 30-35 minutes. Was on the computer)
During this time, the high beam started dimming slightly. This continued with a steady beam, then slightly dimmer for the 25 or so minutes, until the light shut off. I have the XP-G R5 emitter version.
I removed the cell and took a reading which was .7V.
It has been a half hour, and the cell is now reading 3.21V
Can someone let me know what happened, and if the above is the normal operation of the light and/or cell.
I was under the impression that protected cells shut down when they reach a certain voltage. .7V seems pretty low, but I am unsure of the whole operation/shutdown concept.
Thanks.
Edit:
I put the R123A cell in the flashlight, reading 3.425V, but the 4 modes don't work. It lights up in 1 mode, which appears to be a dim high. I'll leave this cell out of the light for now, and not charge it, until I hear if what is happening is the norm or not.
Thanks.
Edit:
