How can you tell which version you have?is there a v36? It's either 35 or 36 I can't recall, but it's not 32 if that's what you were getting at.
Help Support Candle Power Flashlight Forum
...Edit: As long as you charge at the recommended rate of .5C to 1C or 400ma to 800ma with the BC-900 and your 800mah AA cells, using your cooling fan shouldn't be a problem.
I'm fairly confident that 'AA' was just a typo and Russel meant 'AAA' - I'm not aware of any 'recent production' 800mAh NiMH AA cells.If not a problem for AA cells, I'd think it wouldn't be a problem for AAA cells either at those charge rates with the cooling fan on...
The BC-900 has 3 methods to monitor charge:
1) -delta V
2) max temp (It will just pause, not end for high temp)
3) max V...
IMHO, you're hanging out in a BAD NEIGHBORHOOD. 😱 Move to 0.5 - 1.0C and you'll feel MUCH safer... :grouphug:I've only had my BC900 for a couple months now, but I worry about the temperature as well when charging above the neighborhood of .3C...
Buy yourself an inexpensive digital thermometer with a remote probe like the RadioShack one Russel shows in his photo. I have an older RS model and you'll be surprised how HOT 😡 a STILL safe 120ºF :wave: feels to the touch....For example last night I charged a pair of newly discharged eneloops at 1000 mA. They got warm by 1 hour into charging, and continued to get hotter throughout the remainder of the charge. The were not so hot that I could not touch them, but it was kind of like cupping your mug of fresh hot cocoa...
[OPINION]...I was just wondering because I keep staring at this charger over at the ThomasDist. website 🙂
Just out of curiosity, you understand, have you ever considered SEARCHing the CPF Archives and/or READing the (already assembled for you) FAQs?How can you tell which version you have?
[This thread is starting to remind me of the 'mV = Cell Capacity' thread... 🙁 I should log off and go to bed... :sleepy: ]...How can I find out what version I have?
right after you plug in the charger, it displays the version number on the far right lcd cell...
[OPINION]
[/OPINION]
- If you've been using rechargeable cells for YEARS and already have a stockpile of (possibly / most likely) CRAP cells, buy the BC-900 first and then get the MH-C9000 when funds allow (and you can also buy new LSD cells).
.- If you're a "Rechargeable Cell Newbie", just starting out, with a stockpile of NEW 'vibrant' LSD cells, buy the MH-C9000 first and then get the BC-900 when funds allow (and your original new LSD cells are approaching CRAP).
Are you sure about this?...The charger used is a MH-C9000. During normal charging it restricts max voltage to 1.47v before terminating cycle. During the manual (Break-in) mode, voltage is not terminated at 1.47v and the cells were charged to a fuller capacity...
I think what you are finding is that I-C3 cells are not "normal" cells. They contain some internal magic that cuts off the charger when they think they are fully charged. On the C9000 this confuses it, since it will think the battery has been removed and reinserted. On reinsertion the C9000 will forget the break-in cycle and default to charge mode.I'm an 'old' (12/06) BC-900 owner and 'new' (01/09) MH-C9000 owner. I ran a NEW / NEVER USED set of 4 Rayovac I-C3s through 'Break-In' on the C9000 and they finished just fine (which I was planning to communicate to SilverFox). I recently ran a USED set of 4 Rayovac I-C3s through 'Break-In' on the C9000 and they cancelled out and dropped into 'Charge' (for just a few mAh). I re-started them and watched the display (quite often) and they were at 1.47VDC just before the switch. I 'Discharged' them at 100mA (to break down any large crystals) and repeated the 'Break-In' and had the same problem - they dropped back out into 'Charge'.
The cause of the -delta V signal is the rise in temperature of the cell. It is the way the chemistry works; the voltage decreases as the temperature increases. What happens is that when the cell is full and can no longer absorb much charge, the excess current gets converted to heat, and this heat raises the temperature and produces a small drop in voltage. The charger senses this drop and stops charging.
There is no need to use a fan for cooling unless you notice the cells getting uncomfortably hot at the end of charging. Slightly warm or even mildly hot is not a problem.
I think maybe you mean decrease of internal resistance on increasing temperature?The direct cause of the voltage drop is the increase of the internal resistance of the cell, which in turn, is caused by the increase of temperature.
The REVERSE! 😱That's interesting...
...I wonder how many of us have both the BC-900 and the MH-C9000?
Anyway, would you use the BC-900 for charging the 'vibrant' LSD cells and the MH-C9000 for the older, delapitated cells?
My 'NEW' C9000 has been running 'Break-Ins' on my existing inventory, 24x7, for 6+ weeks now. And just recently, I got the 'Bright Idea' :tinfoil: to also track Internal Resistance via the C9000's initial voltage reading. Cells that register 'HIGH' on the C9000 go to a 'Refresh 200/100' on the BC-900, hoping to break down the large crystals that formed from my neglect (read about 'Storage Box Queens' in my Sig Line LINK). Due to the different design of measuring discharge 'Under Load' (C9000) vs 'Off Load' (BC-900), the BC-900 can drain 'neglected' / high resistance cells lower (closer to 0.9VDC) than the C9000....Or, maybe I should just ask you: How would you use the two chargers with a combination of new LSD cells and older, more questionable cells?
Thanks for your relenting, and speaking your mind. Yeah, I joined a while ago but took a sabbatical. I haven't hung out here steadily. I'll try to be a better citizen. :wave:Just out of curiosity, you understand, have you ever considered SEARCHing the CPF Archives and/or READing the (already assembled for you) FAQs?
:welcome: [Join Date: Mar 2007] 😕
CPF Post #97 (12-31-2005, 04:59 AM):
This does not sound logical, though. What use would the "Test" mode be if it did not test the capacity of the battery and display it to you on completion?Sorry if this has been mentioned, because I haven't read the next two pages of posts. "Test" on the LaCrosse will only dispay discharge capacity while discharging. As soon as it begins the next charge cycle, the discharge capacity is erased and "accumulated" capacity is displayed. So unless you are right there at the charger observing the discharge current as the voltage hits 0.9 volts, the displayed "capacity" of the cell at end of test is not the discharge current, but the accumulated capacity. The only mode on the LaCrosse which retains the discharge capacity in the display during the subsequent charge is refresh mode. Just wait for it to go to charge, note the discharge capacity, then if you don't want another refresh cycle, simply unplug and plug back in the wall wart and set your charge rate.
This does not sound logical, though...
Are you saying this is not what actually is displayed in reality?
