CONS:
* lenght measured wrong, even the 17 mm reflector was a bit too long, sanded 1 mm away from it.
Unfortunately the 19 mm in the 6P mod gives a bit a better spot
* spring at Flupic sodered in ugly (iron too hot), but it works
* even as my mechanical skills improve, there still are boring errors:
front part wiped immediately after freeze-pop, put into sealed back, never touched.
Light engine put into body (see pic above) with no debrits in reflector at all, epoxied it in. After putting glue in place, took the light to warm place to improve glue --> no debrits in reflector.
After having it rested for some hours, with reflector looking up, never touched in between, there is this whatever down and left on the surface
AND
took front part out of its sealed bag, checked it with a light from behind: plain perfectly clean. Took body with other hand, placed front part and body together and then took it to vise to press both together.
After this, there is this white dust particle inside the housing (the one that is above the cree metal ring, the 2nd is outside).
dumb dumb dumb (but no clue what I did wrong)
totally crazy that I'm a bit disappointed because the 19 mm in the 6P makes a slightliy improved light, even this one is great.
:Ohgeez:
