Anyone have any help with this issue, or experienced this before?
I agreed to install one of the newly available (to me anyway) Nichia Hi-CRI 219 emitters into a member's Surefire U2, and everything went fine, until I tested the light and found that the lowest two settings on the rotary dial work fine, but starting at the third level, throughout the remaining levels, the emitter gives off identical output (at least no perceptible change in output).
I tried to troubleshoot by installing a cree xpg, and the same problem was present. Re-installing the stock emitter (I'm not even sure what it is, too new to the flashlight game I'm afraid😱) resulted in a return to normal operation.
I haven't asked the customer if it is acceptable for the light to only have three modes, because to me that seems unacceptable. Has anyone had this problem with an xpg install, and if so, is there a fix?
I've thought about whether the Vf of the newer emitters is lower than the stock emitter Vf, but I have no idea why this would effect the current output level of the higher modes. Also, I've read threads describing xpg emitter swaps with no mention of reduced mode level function.
Help!?!
-Jon
Help!?!
-Jon
