integrating circuit for charging and optional auxiliary supply
Z
z_RodneyMcKay
Guest
Heho...
as the topic states, i'm looking to integrate a complete Li-ion charger into
a flashlight. Because this yet to build flashlight would be used every day
primarily as bike light, i don't need the fuss of endless disassembling and
recharging. I think, hooking the bike up to it's wall mount and just putting a
plug into the tail is a decent procedure. The light is going to be a single
XM-L, mayby slightly overdriven (max 3,5A). The new XM-L hits, as i see it,
some walls. Since i only want a single battery and 18650 proven to be on
edge and can't sustain 3A for more then a few minutes, i will probably go for
a 26650 IMR. The high current makes usual clicky switches a pain in the ***
an so i will use a MOSFET (or i opt for LFlex). My first choice on that
matter is the IRLR3717 with a drain to source resistance of 0,004Ohm and
gate threshold voltage ranging from 1,55V to 2,45V.
http://www.irf.com/product-info/data...a/irlr3717.pdf
Second in row: IRLZ34N (R(ds)=0,035Ohm, V(gs)=1-2V).
http://www.irf.com/product-info/data...ta/irlz34n.pdf
Both are working well without any additional parts, btw.
I suppose a quick and dirty way would be to just wiring jack/plug to the output
of a Li-ion charger. But i would rather take a more sophisticated approach witch
provides more flexibility. A jack for a here in germany quite common
2,1mm round plug (Hohlstecker) and a charging circuit with an input voltage,
ranging from 5-12V (or 5V and powered by a LM7805 constand voltage regulator)
would very versatile and enable the use of a wide range of wall power supplies,
wich can be found almost anywhere. Only one cell to charge does not requiring
load balancing or some other fancy obstacles, so it should proven not to hard.
Because my bicycle is completely lawful, hence equipped with mandatory lighting,
wich is powered by a Shimano DH-3N80 hub dynamo. I read once, this dynamocan
easily provide 10W energy if the electrical restraints are removed. If i
calculate the energy requirements for the front Lumotec IQ Cyo senso plus and
the little red led rear light.... there should be at least 5W left over.
And yes... of course i would love to see that otherwise wasted potential fed
directly into the battery draining XM-L. Bottom line.... i need a ciruit that
will be able to recharge from a wide range of DC Voltage while the torch is
switched off as well as benefit from pluged in auxiliary sources if it is
lighten up.
Concerning the first goal, charging circuit... i'm not sure wich way to go.
There are a lot of highly integrated sophisticated special chips from Maxim or
Linear Technologie... on the other hand, a simple solution with discrete parts
like LM317T/LM350/L200/etc. might very well suffice. At this point, i can only
guess and any hint or advice would be appreciated.
On how to implement the auxiliary rail and the dynamo hub tweak.... i'm even
more in the dark and still more in the idea state. Any suggestion and ideas
here are most welcome as well.
... on a personal note:
As you can see i'm fresh flesh on CandlePowerForums. With electronic, i recently
revived a long abandoned interest and short after that, i got infected with the
flashlight virus. This community is great and as competent as i'm used to like
on the usenet/newsgroup, you know, back in the old days.....
There is an almost inexhaustible amount of information here, all very
interesting and relevant, which kinda constitutes a problem for a bloody
beginner like me. Even though i handle information like the Borg - by
assimilating it, preferbly entirely, i get absorbed by it.
But at some point, you actually have _to_ _do_, rather then read and learn
about it. Anyway... i startet about ten weeks ago out of frustration over
this one: http://xcell-batteries.com/index.php...en/xcell_3030#
Plastic lens, plasic reflector, 3xAAA, only XR-E Q4, hence insufficient power.
Now it has a XM-L@4A driven by a single 32650 Li-Ion DCell, embedded in a decent
alu smooth reflector and not behind plastic, now the whole thing has grown into
what i call a flashlight.... :) After that i upgraded an old 3D Mag (weird
construction btw, looks like french engerneering....) with an SSC P7 and since
this point, i got addicted and i'm in the devils circle, more, bigger, brighter..
I guess there is still some inevitable collateral damage ahead of me, like
i destroyed four XP-G R5 emitter while figuring out a working method of reflow
soldering them. (in the end, the electric iron made it, btw)
I still have a lot of strange ideas that need to fail before i can settle
down, i guess. So... after the topic of this post is water under the bridge,
i will approach the tricky heat issue with ab bunch of heatpipes from countless
old nootbooks.
Greetings from Berlin
Martin
