Interesting headlight bulb test results
-Virgil-
Moderator
Staff member
As part of a larger project, I needed to run photometric tests with different bulbs. All lamps and bulbs were run on the same goniophotometer, on the same power supply set to 13.5v. I can't share the entirety of the data, but here are some of the highlights from four bulbs tested in two new H4 headlamps.
Bulb "A"
Standard Philips H4 12v 60/55w (p/n 12342), made in Germany
Measured 73w high beam, 64w low beam at 13.5v, which calculates to:
60/53w at 12.0v
67/59w at 12.8v
70/62w at 13.2v
Bulb "B"
Osram Rallye/Hyper H4 12v 70/65w (p/n 64205), made in Germany
Measured 76w high beam, 68w low beam at 13.5v, which calculates to:
63/56w at 12.0v
70/62w at 12.8v
73/66w at 13.2v
Bulb "C"
Philips HB2 + H4 Xtreme Power 9003XP 12v 60/55w, made in Germany
Measured 73w high beam, 69w low beam at 13.5v,
60/57w at 12.0v
67/63w at 12.8v
70/67w at 13.2v
Bulb "D"
Philips H4 12v Rallye 100/90w (p/n 12569), made in Germany
Measured 90w high beam, 82w low beam at 13.5v,
75/68w at 12.0v
83/75w at 12.8v
87/79w at 13.2v
For frame of reference, the US standard for the "60/55w" HB2 (9003) is 72/65w max at 12.8v, and the UN/ECE standard for the "60/55w" H4 is 75/68w max at 13.2v. So bulbs A, B and C all meet both standards in terms of power draw. Luminous flux data (lumens) from these bulbs cannot be shared at this time.
Figures given below are peak intensity in candelas, peak intensity location in degrees from H-V, and beam flux content in lumens.
Headlamp #1, designed to conform to an old variant version of SAE photometrics:
Bulb "A"
High beam: 45,260 cd at (0.2° D, 1.2° R), 855 lumens
Low beam: 14,910 cd at (1.6° D, 1.2° R), 524 lumens
Bulb "B":
High beam: 43,860 cd at (0.2° D, 0.8° R), 976 lumens
Low beam: 22,060 cd at (1.6° D, 0.8° R), 650 lumens
Bulb "C":
High beam: 47,110 cd at (0.4° D, 1.4° R), 903 lumens
Low beam: 20,850 cd at (1.4° D, 1.4° R), 615 lumens
Bulb "D":
Not tested with this headlamp
Headlamp #2, designed to conform to UN/ECE Regulation 20:
Bulb "A"
High beam: 55,410 cd at (0.2° D, 0.6° R), 846 lumens
Low beam: 14,430 cd at (1.2° D, 1.8° R), 451 lumens
Bulb "B":
High beam: 55,810 cd at (0.2° D, 0.4° R), 979 lumens
Low beam: 19,490 cd at (1.2° D, 1.5° R), 545 lumens
Bulb "C":
High beam: 59,650 cd at (H, 0.4° R), 923 lumens
Low beam: 20,220 cd at (1.2° D, 1.6° R), 556 lumens
Bulb "D":
High beam: 69,680 cd at (2.8° D, 2.4° L), 1260 lumens
Low beam: 18,720 cd at (1.8° D, 1.6° L), 677 lumens
Before we go too far in drawing conclusions from these results, it must be stressed that only one sample of each bulb type was tested. That was adequate for the purposes of the larger project involved, but to avoid the possibility of an outlier bulb if these results I've posted were the end intention of the project, it would be preferable to run the tests with multiple samples of each bulb type. Nevertheless, the geometry of each bulb was checked and found to be within the specified tolerances, and nothing about the power draw measurements suggests an off-spec bulb.
Probably the most interesting thing to see here is the close similarity between the Osram 70/65w H4 and the Philips Xtreme Power H4 in both power draw and beam performance. The flux in beam differs by no more than 8% between the two, which is very close -- in fact it is well within the variance I would expect to see between two samples of the same bulb type (two of the 70/65w bulbs or two Xtremes, for example). The beam peak intensity difference between these two bulbs is likewise quite small, no more than 7%. Again, this is well within the range one would expect to see from two samples of the same bulb type, which is why it is an interesting result from two different bulbs from two different manufacturers. For all practical purposes, based on these tests the Osram "70/65w" and the Philips Xtreme Power "60/55w" bulb must be considered functionally the same. Further bolstering this conclusion is these two bulb types' very comparable lifetime ratings. (It is reasonable to assume the newer Philips Xtreme Vision would be in this same group of bulbs; I may or may not be able to get some data from at least one of these headlamps with the XV bulb before the project is over, but not at this time.)
We can also see the peak intensity moves around a little from bulb to bulb, but there's nothing here that is surprising or indicative of anything in particular; we expect to see this kind of movement even among samples of the same type of bulb. Also we have to remember that the peak intensity doesn't tell the whole story; it is just one tiny point within the larger high-intensity zone in the beam, and so we can't draw any headlamp performance or seeing distance conclusions by comparing the exact location of the peak intensity with one bulb versus another bulb.
Also interesting is the showing of the Philips 100/90w bulb. This is (by long experience) among the best of the 100/80 or 100/90 rated bulbs. Its actual power draw is less than advertised. This is not a surprise; the power ratings on off-road bulbs have long been mostly about selecting a round number somewhat above the actual power draw of the filaments. Flux in the beam is elevated compared to the other bulbs, but it's within 4% of the Xtreme Power and within 10% of the 70/65w on low beam in headlamp #1. But look at the peak intensity on low beam with the 100/90w bulb -- there's a surprise! It's lower than any other bulb except the standard Philips 60/55w. Bigger difference (benefit for the 100/90w) in flux and intensity on high beam, but now we do have a larger amount of movement in the location of the peak intensity. It's almost 3 degrees down and almost 2.5 degrees left-shifted relative to straight ahead with the 100/90w bulb, compared to the almost-centered location with the other three bulbs.
At the other end of the scale, we see that the 70/65w or the Xtreme bulb really does make a stout improvement over a standard bulb. 17% to 24% more low beam flux, 16% to 29% more high beam flux. 35% to 48% greater peak low beam intensity (in these specific headlamps) with practically identical high beam intensity. Given that the threshold of just-noticeable intensity difference is 15%, those low beam intensity boosts are pretty "juicy" and worth getting.
For quite a while when I have needed an H4 bulb for a frequently-driven vehicle, I have grabbed whatever comes to my hand first, an Osram 70/65w or a Philips Xtreme, never really forming a preference one way or the other. This set of data helps explain why; there's really no overall advantage to one versus the other, and they're both about equally better than a standard bulb.
Alaric Darconville
Moderator
Staff member
Stillwater, America
Side effects of the larger filament? I suppose that with the reduction of the peak beam intensity comes a reduction in reach, but the beam is brighter in a broader section of the hotspot, as well. Or am I getting out of this nothing that you put in?
So, either of those two would be great for the Previa, 'cept for the rather thin wiring, I take it. Someday I'll get that all relayed up! I might also try to do the high/low-in-series mod for a DRL, just to say I can. Not that I'm particularly enamored with DRLs, but maybe if I ever hop up to Canada I can be all DRLed and stuff. DRL!
Loko
Member
Thanks for the test Virgil! :thumbsup:
I use H4 Philips Rally, made in Germany and Brasil.
robertkoa
Active member
These are very interesting.
It seems optimum "sweet spot " for low beams if optimised may be about 65 to 75 watts.
Meaning a definite improvement in lumens .
And most wiring can tolerate 1 amp more.
IF DOT slightly relaxes voltage testing , rating at 11.5 -12.0 we could have new designs which run low beams
AND high beams at 70 to 75 Watts, to avoid going too high in Wattage.
Since operating voltages in USA will be 13.0 -14.0 a little loophole can exist.
Hi Beams may not need to be higher than 70-75 , we can get superior performance and safer driving IF er properly aim the beams.
-Virgil-
Moderator
Staff member
That conclusion can't be derived from these results.
IF DOT slightly relaxes voltage testing , rating at 11.5 -12.0 we could have new designs which run low beams AND high beams at 70 to 75 Watts, to avoid going too high in Wattage. Since operating voltages in USA will be 13.0 -14.0 a little loophole can exist.
The US vehicle lighting regulations are already considerably more permissive in many ways than those used elsewhere in the world; they do not need to be relaxed. All bulbs are tested at 12.8 volts in the US regulations, which are statutory (that is, they are Federal law). That 12.8v figure is already considerably lower than the operating voltage in many vehicles; if anything, it would be more realistic to rate bulbs at 13.2v or 13.5v as is done outside North America. There is no technically sound reason to specify bulbs at 12 or 11.5 volts, which would be even further away from the actual operating voltage.
There is no direct link between wattage and output. We do not measure headlamp output in watts, so it really doesn't mean anything practical in terms of seeing to talk about a "70-75 watt high beam".
That said, the situation you describe already exists. Remember, the common wattage ratings (like "60/55w" for an HB2 or "65w" for an H9) are just nominal ratings. Take a look at the list of headlight bulbs recognized by the US regulation (somewhat out of date, but all listed bulbs are still valid with unchanged specs). Look at HB1, HB2, HB3, HB5, H9, and HIR1...all with filaments allowed to run at 70 watts or slightly higher, at the official test voltage of 12.8v. Run them at realistic operating voltage (say 13.5v) and those filaments allowed to run 70w at 12.8v are running 76w.
Yes, headlamp aim is the primary determinant of how well the driver can see.
