Hello All,
After seeing wquiles "poor man's integrating sphere", http://candlepowerforums.com/vb/showthread.php?t=111538, I decided to make something similar to measure overall output instead of just lux.Not knowing how my design would work I threw something together to see how it would go.It is by no means the quality of wquiles box,but I am very pleased with the results,so much so that I intend to re-make the box out of new material with the same dimensions.The material is white laminated MDF.Before anyone says so I am aware that this is by no means scientific,or even reflective of actual lumens,the results were very surprising though.All measurements were taken with the meter in the x10 Lux Range.
L2DCE P4
Advertised Lumens
Low 9
Med 40
High 80
Turbo 135
Lightbox Measurements
Low 16
Med 45
High 82
Turbo 135
I was so surprised to see the numbers so close I decided to charge the Eneloops and let them rest overnight,Then I repeated the tests.The results were surprisingly the same.Oh yeah,the meter is a Protek 6300.So what do you think.
L2DCE P4
Advertised Lumens
Low 9
Med 40
High 80
Turbo 135
Low 16
Med 45
High 82
Turbo 135
