interesting volt/amp/watt ratings
dano
East Bay, Cali.
I was bored, tonight, so I fooled around with some multi-meters, and tested most of the 2-cell flashlight lamps...here's a quick breakdown:
P60: 1.1amps @ 4.9volts = 5.39watts
Scorpion: 1.15amps @ 4.98volts = 5.73watts
UK 2L: .43amps @ 5.48volts = 2.36watts
Legend LX: 1.20amps @ 4.90volts = 5.88watts
E2: 1.07amps @ 4.72volts = 5.05watts
ASP: 1.19amps @ 4.99volts = 5.94watts
Pretty interesting numbers. Runs were done with new Ray-O-Vac 123cells. Overall, they make sense, with most 2-cell lights claiming 1 hour of run time, and the Ray-O-Vacs are rated at 1400MAH, and most other 123-cells are rated at 1200-1300MAH.
--dan
dano,
ta very much indeed.
If you get bored again, any chance of the same for the SF P61, P90 and P91 ?
lightlover
The Ray-o-vacs were from Target...I have a P61, but it's in my locker at work...I also have a P90/P91, but have to mickey mouse a battery holder for three cells...I'm working on it, and a rig to to some readings on some Streamlight bulbs, as well...
--dan
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by dano:
--dan
<HR></BLOCKQUOTE>
Dano,
You seem to accomplish more when you're bored than many people when they're motivated.
How much are those Ray-O-Vac 123's and where did you get them?
Best regards,
Brightnorm
The Ray-O-Vacs were 8.99/pair at one target, and today, at another Target, I saw them at 10.99/pair (ouch)...Just as a side note, the Ray-o-Vacs appear to be identical to the Surefire SF-123 cells...
--dan
