internal boring for 26650 cell - with photos ...
Candle Power Flashlight Forum
Help Support CPF:
wquiles
Texas, USA, Earth
Well, of course it will have "some" photos ...
A forum member recently sent me 3x Leif "C" size extension tubes that he wanted bored for the 26650 cell:
I did some measurements to see how much I had to remove. Fortunately for me, there is plenty of metal thickness available:
I am using my Al insert on a 7/8" solid carbide boring bar (barely fits inside a "C" size tube!):
Here is my full setup:
Although I have the Accu-Lube, it is hard to get cutting fluid inside the hole so I squirt some LB-2000 prior to starting:
While I am cutting:
Finished - did a single pass on each tube (DRO set for 0.006"):
Cell fits comfortably in the bored tube (not a tight fit, but not loose either):
Based on the specs on the cell, the theoretical max. OD was 1.040". My first tube ended up being 1.041", and the other two (leaving the lathe as before - no adjustments; just removing one tube and chucking the other one) were withing 0.001" - not bad:
I love it when everything goes according to plan 😀
Just curious, what did the cell measure? A snug fit might be too tight when the head is installed & air tight. Better to be on the loose side so there's no vacuum when the end user installs or removes the cells. 🙂
Nice Job
Of course, you could use a coolant through boring bar....
If he had a coolant pump attached.
That carbide boring bar "is" a coolant through boring bar, but I don't have a flood coolant setup for it. Since my Accu-Lube has two output nozzles, I should "convert" one of them to work in the various through coolant boring bars that I have - one of these days 😀
Nice work.
When I initially looked at the picture below, I thought "Why is he censoring the cut?" 🙂
Yeah - I felt the same way when I was re-sizing the pics for posting. I went back and removed the sticker from the safety shield so next time it will give a better view 😉
I measured several cells in an earlier project, and that is how I came up with the 1.040" "target". The cells moved freely with no friction, but I will wait to hear from the customer to see if he is happy.
Will that looks awesome I am jealous of your lathe big time. Someday soon I will have one in the garage 🙂
I have the exact same BigLeef setup, and as you know, these won't fit IMR 26500s or 26650s. I need them bored out in the same way you did the ones in the OP. Are you taking new (paying) customers? If so, how do I get in the queue?
Thanks,
-John
Thanks,
-John
John,
I just stopped taking new orders to finish a new project, but now that I have done these and I have a known-to-work setup, I can make a quick job for you. Send me an email at
wquiles ( at ) gmail [ dot ] com
Will
John,
Will
Hi Will,
I bought this package from GunSmoke16610 and one more bored C section would allow me to use three 26650. Will you bore out this extra section?
Thank you,
Frank
