First Responder SST-50 LED flashlight:
FR1200A is a very high power light with over a 1000 foot, (300 meter); throw in a very small package.
As such we do not recommend that maximum output be used for over 10 minutes do to heat build up. I did
run the light for 20 minutes straight with no problems at full power, but it is hard on the batteries as they
do heat up. The battery compartment got to 127 degrees Fahrenheit sitting on the bench. The batteries used
were AW brand 2200 mAh units that are about 4 years old. High performance means heat, this is a light
for the professional and not for children or the uninformed. It is also very, very bright and could cause eye
damage, so be careful.
That said, now on to the facts of the light:
The head diameter is 1.62 inches, (41 mm), by 4.75 inches, (121 mm) long.
The battery compartment is 1 inch, (25 mm), by 6.75 inches, (172 mm) long.
The total length is 11.5 inches, (292 mm) long.
The weight with two 18650 batteries is 15 oz, (425 g).
The light output is fully adjustable from maximum to off by a control knob on the head. Maximum drive current
to the SST-50 LED is 5.2 Amps at 3.75 volts for an output of up to 1650 Lumens. The Lux output is 50%
greater than the FR400 and double that of the FR1000 with the Seoul P7 LED driven at 3.4 Amps.
The beam pattern is almost identical to that of the FR400 with a very sharply defined hot spot with some side
spill. The hot spot appearance seems to be of equal intensity from edge to edge and the side spill also seems
to have almost no variation to it to the very edge of the light cone. With the FR400 you can detect slight
blotches and a hint of the square outline of the XP-G R5 LED in the hot spot area. With the FR1200 SST-50 it
is round and completely smooth. It is a very good combination of LED and optics.
We will be shipping these to RMSK on Monday the 24th of May 2010. We will handle overseas and paypal orders at Peak.
Curt
Curt
