Is it safe to use AW RCR123 cells in LED Surefires?
Yes, ok with the older KL1 head that can run with 3-9 volts safely. It is buck/boost. I have had two and they ran just fine with no noticeable difference in output using 2XCR123, and 2XRCR123, which I tested using bounce with a lightmeter.
Bill
The KL1 isn't the most modern (KX1 and KX2 has superseded it), but it is one of Surefire's best with an input range of 3-9v. Hang onto that one...
Thanks for the replies. And i do plan on keeping this one, I really didnt know what i was getting when i bid on it(on ebay, I won it for $66), But i like it alot. It sure is bright for only 33lm.
