I ordered an Ultrafire WF-606A Q5 (sku 14909), and its been a bit disappointing. I was wondering if all DX flashlights are this quality, or if I just got unlucky.
A few of my complaints
-threads are not clean cut - pretty jagged
-bone dry threads and o-rings
-very thin walled tube - feel like i could crush it when empty
-anodizing isn't matched between parts
-different sections don't seem to screw together all the way as they should - when tightened all the way, there are gaps where there shouldn't be
-the dome on the LED had a little defect on the side, an extra tiny bulb of plastic that I was able to knock off with my fingernail
The biggest problem was that the clicky switch broke about 2 hours after I got the light. I completely disassembled the rear section and pulled apart the switch (I really had nothing to lose). The clicky mechanism looked just like that in a clicky pen, but it was clear that poorly molded parts were causing the switch to get stuck. I put in a tiny bit of lubricant to get it moving more smoothly. It works most of the time now, but I don't have 100% confidence in it working when I need it.
I contacted DX before I pulled it apart and they offered me $5 for sending me a light that broke after 2 hours. I realise that this was part of the risk of buying from them - theres not an easy way to get it back to them. If I hadn't been able to get it working again, I would have paid $17 for a broken light.
So, when looking at other lights, can I expect this poor quality from all the lights on DX, or are some better built than others?
