FlashlightKid
I am in to process of deciding which hobby charger to buy to charge 18650 and other rechargeable batteries with. I believe that the Cellpro Multi 4 is the best suited for my task without over spending on a charger.
I read the manual and it seems it has both features I want but just wanted to make sure that it can do both and see what else you may recommend. Again I only need it to charge 18650 and similar batteries, not NIMH or battery packs and I don’t want to spend too much if it gives me features I don’t need.
Two features I need:
1. Ability to set the ending charge voltage manually. I want to charge most of my cells to 4.1v in order to keep my batteries longer and some to 3.8v to allow them to remain in storage for a while.
2. Ability to view the MAH charge put into the batteries in one particular charge DIRECTLY on the charger screen. I need this to be accurate enough to help me track the cycles put on the battery so I know about when to recycle them. I was planning on keeping a log for each battery and based on the manufacturer MAH and total accumulated charge MAH I can estimate the number of cycles the battery has been though.
I also had a question about setting the charge current. For AW and Ultrafire 18650 what is the optimal charge current to preserve battery life yet not take days to charge (I don’t need to speed charge).
Thank you for any recommendations and advice.
