AvPD
I'm having trouble getting exact and equivalent specs and was wondering if someone could answer this authoritatively.
According to the datasheets;
The MC-E K bin is a minimum 370lm @ 4.48W or 82.59 lm/W
(350ma and 3.2V typical,going by the datasheet)
The P7 C bin is typical 400lm @ 4.62W or 86.58 lm/W
(1400ma @ 3.3V,again,going by the datasheet.)
Quite honestly,I think its a wash.
Some things to bear in mind;
The datasheet for the P7 list typical Vf as 3.6 @ 2800ma.The C bins that are currently available are a maximum of 3.5 Vf at 2800ma.So it seems the available product will actually be more efficient than the datasheet would indicate.
The same seems to hold true for the MC-E as well,the samples that have been tested so far have been below the datasheet spec of 3.4V @ 700ma.McGizmo tested one at 3.3Vf @ 700ma,again,better than the datasheet would suggest.
This,coupled with the fact they use the same die,leads me to speculate they will be equal as far as efficiency.
As a side note,the D bin P7's are widely available now,and the M bin MC-E has also shipped from Cree.
-Michael
I just downloaded the latest P7 spec sheet for pure white that doesn't even mentioning binning (just says 700lm typical, 900lm max). 700 lumens from 3.6V x 2.8A = 10.08 watts is only 69.4 lumens per watt, so that would mean that the efficiency drops off quite a bit above 1400mA.
If they're basically the same efficiency than Cree's only advantage would the smaller size and individually addressable dies.
Good post Michael!...
I'm not that lazy (had a copy on my HD, and have re-downloaded it from http://acriche.com/en/product/prd/zpowerLEDp7.asp) and I have not been able to find any of the figures you have quoted from it. Only that general spec sheet had a voltage and amperage figure.Download the P7 binning and labeling pdf,the standard spec sheet dosen't have the binning info.
A P7 CSWOI for instance,would have a max Vf of 3.5.At 2800ma(9.8W),while producing between 700lm-800lm.The lowest possible efficieny with that emitter would be 71.4 lm/W,using 3.5Vf and 700lm.
I'm not that lazy
By the way I appreciate your input, I feared the thread would fade away unanswered.
I think that Vf binning is for 1400mA current (350mA per die) not for 2800mA.
I hope I didn't come across as combative
Looks like the only piece of information missing is the MC-E's lumens at 700mA per die/2.8A total
