Is the DB 18 LED worth...
Elmie
Toronto, Ontario
I'm thinking of getting one of these bad boys. I'm just wondering if it is really worth the 100 price tag!
Just want to know others opinions on this matter. How is it compared to the the trek 1900 light in terms of light spread? I'm leaning towards the DB for reasons such as; Telephony seems to really like it! The overall construction of the unit, being that it has a button and is partially made of aluminum. Just seems like a much better light than the trek.
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Elmie:
I'm thinking of getting one of these bad boys. I'm just wondering if it is really worth the 100 price tag!<HR></BLOCKQUOTE>
That depends... in part on what you need from an LED flashlight, how badly that $100 might be needed for something else, and how obsessed one is with finding a decent flashlight.
The DB18 feels substantial in the hand, the switch is nice, and it's plenty bright enough to replace any flashlight for any purpose except for distance, where an incandescent spot might be more appropriate.
$0.02
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by telephony:
$0.02
<HR></BLOCKQUOTE>
Well how far does the light "throw" ahead, in say complete darkness?
Do you think something like this will be suitable for camping...say while hiking at night?
Thats the kind of usage this light will be for.
I have the Eternal light, but it doesn't throw the beam far enough for distance usage!
Well how far does the light "throw" ahead, in say complete darkness?<HR></BLOCKQUOTE>
That I may not be qualified to answer.
I live in the center of a major city's retail district, and it never gets dark here like it would on a typical campsite.
There are dozens of 1KW sodium vapor lights, thousands of feet of neon tubing, and thousands of miniature incandescent lamps all around outside my window and throughout dozens of neighboring blocks.
The dimmest celestial objects I can see are probably around magnitude -4 because there is so much light pollution here.
That should put things into perspective.
If anyone else has a DB18 and lives or can get to a darker area, please feel free to field this guy's question... thanks.
The DB is one of the brightest lights that I have at the moment. The other 2 are Trek 7 and Nightbuster.
While it may not be as bright as the 19 leds Expedition, I think it is 20% and 10% brighter than the other 2 respectively and with a wider beam.
I don't like the construction of the Trek series of light as it feels bulky and at $135 for 19 leds, I think it is over price.
The DB allows 1 hand operation, look good, and well made. Those who have tested it mentioned that it does not over drive the leds and I believe it is a plus point. Of course, if you want a brighter light you could probably drop a mail to the seller to put in lower resistors to drive the leds a little harder. He may oblight you!
Construction wise, the nightbuster is better than the Trek 7, brighter than it, and cheaper.
Regards
I really like my DB18- it`s bright, good looking, well made, has a real nice switch and the fact that it uses cheap common batteries is a definate bonus (and you can refill just one "barrell" if you`re short on $$$ and don`t need the full runtime). As for how far it shines? Well I`ve taken it outside a few times now, mostly round the garden but once down to the shop too. It really lights up the path infront of you quite far with its pure smooth white light, and that is where it performs best, but it will also easilly shine about 100ft or more, just spreads out and gets really wide and not so bright. Quite like bright moonlight. It`s never really properly dark here in Suburbia though but out in the middle of nowhere away from the city glow this light is going to shine fairly brightly enabling you to see quute far. Craig`s right of course, that a good incandescent is best for shining the furthest- keep one in your bag for those occasions.
Personally I think the DB18 would make a great camping/walking/hiking light. It would floodlight the trail ahead and you`d not fall over any unseen cliff edges or trip on tree roots that easilly!
I don`t yet own any of the Trek lights but they do look quite heavy and bulky, and of course then there`s that grip-of-death head switch too, though I hear you can take out an O-ring to make life easier. The DB18 won`t outshine the 19-LED Trek (probably no LED lights will at the moment!) but by my standards as an indoors person, it wins on style, functionality and versatility.
As Craig said it`s really up to you- how much do you want to spend? Perhaps you may think the $100 is a little on the expensive side for a LED flashlight- a SureFire costing that much would far outperform it in brightness and compactness but remember this light will last a lot longer on inexpensive batteries (not sure how long, if batteries were cheaper round here I`d miss another nights sleep and see for myself) and the LEDs will last a lifetime since they aren`t overrun, and won`t break if it falls on the floor. The flat profile is handy as an anti-roll aid too.
I like it.
I think the DB 18 is the best large LED light available at the moment. It looks good worked and has the brightness you need from a large light. The only alternative I see is building your own, but at 100$ I wouldnt think about because you pay about 3$ per LED at the moment so you get 54$ worth of LEDs and about 25$ worth the flashlight, so the rest is worth the work of converting. For 100$ it is an absolute "take-it"
Bye,
I don`t have a DB 18 but I think the ability to run lithium is a plus. Use the one`s marked 2011 for long run time...use the one`s marked 2010 or earlier for increased brightness.
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by KenB:
I don`t have a DB 18 but I think the ability to run lithium is a plus. Use the one`s marked 2011 for long run time...use the one`s marked 2010 or earlier for increased brightness.<HR></BLOCKQUOTE>
Huh? What? What is the difference? I have heard that there are 1.7 volt versions of theses batteries, but the one I have here is dated 2010, and it says 1.5v .... or is that wrong (no volt meter
Doug
Hi Doug, hit your back arrow and scroll down to "AA lithium.......ok to use in Turtle light" or somthing like that. Basically all lithiums AA are marked 1.5 volts...but it looks like the one`s that expire in 2010 or before are really 1.7 volt...we think there may have been some complaints about damaged electronics duo to the higher volts and the problem was "fixed" in the one`s that expire in 2011. As the new one do not dump there amps as quickly they should have a longer run time... as the old and new have the same total capacity. Hope this helps and hope it is correct, help me out if someone knows more
