Got my Nightbuster 8x an hour ago on Brock'ters orders. This sturdy led-lined nightstick handles like a nice old fashioned sturdy 3c flashlight thingy. It can replace the 2-D Ray-O-Vac for household lighting duties only it's not as cheap.
It's not a ShureShot/Fire device. No-no-no. It's not beautiful but it's at least half way attractive. It comes WITH paint and all. It even has a lanyard, for your wrist, not your neck. I can't find any "made in china" markings on the body, the endcap, the head or the instruction manual so, unless they were painted over, I guess it's good old USA made, hopefully in St. Louis Mo. where the designer/company lives.
I quickly popped in three charged Ni-cads, turned it on and looked down the barrel of the gun. Kind of blinding down there but not quite. I took my eyes away right quickly, But I could actually see the individual LED's without much pain at all.
It's daytime right now so I did the closet trick with an eternalight for comparison. Hey, I'm still in the closet but the door's open.
The spot on back of the closet, with the door open but the curtains down, made by the Nightbuster seemed about 2-3 times bigger and almost as diffuse as the one made by the eternalight. Both Ledlights, one on charged nicads and the other on pretty fresh eveready E-91 alkaline AA;s seemed to have about the same blinding effect. You could actually look at them for a second.
I replaced the nicads in the Nightbuster with regular fresh but not new E-91 regular formula Eveready Alkalines the light was pretty blinding but it wouldn't leave a spot on the back of my brain or on the floor of a non-sunlit room (am I sounding like Craig...?) It definitely outlit the eternalight, as it should given the relative amperages consumed per each LED, (Per Brock)
So I stuck in three not-so-new but plenty good, tested, e2 L-91 lithium batteries and stuck the light in my eye. Wow. I saw spots for about 15 seconds. It's a rush. Good and plenty. That's my equivalent of rolling a motorized wheelchair over the light body.
Craig and I will have to build a chart of relative destruction lest we perpetuate mind/body dualism.
Caution, this was done by an expert who have done this before, who has day-accustomed eyes who is not depressed with light-sensitive eyes and I know what I are doing.
No more than a peepsight, you hear, just a second or so...or you will get brain damage too. I have seen 360 lumens and lived.
This Nightbuster 8x is pretty strong but it may not as useful-for-biking throw-your- weight-around strong as your basic high lumen halogen light, much less your basic cheapo yellowy PR 113, 700ma Krypton bulb with four L-91 lithiums in a plastic body.
The Specialized Pre-view Krypton light I use for backup with L-91's easily wiped out the 8-LED array on L-91's. No change when I switched the bike light to a (chinese) Halogen bulb at 500ma I wiped out the Nightbuster beam at 10 feet. I could probably have stepped the bike light back down to Nicad's on the Pre-View light and outspotted the Nightbuster. The Buster is just not a spotlight.
It does not even have a reflector...just 8 LEDs peering out of a deeply sunken aluminum cylinder with a clear plastic cap.
I want a reliable bikeuplight for my back.
I ride bikes, commuting, every day. Even when it is very very cool out. I even do trail riding, in Chicago no less where backups are critical lest one bite the dust.
My 360 lumen Light & Motion Apex-Cabeza headlight with the 20 hour softstart light and the NIMH batteries sometimes stops. Mostly because it is real new and does not take a full charge but sometimes because I drained it. When I ride more than an hour...its surefire flameout for me too, just like when a M-6 does a 500 lumen flameout while you cut grass with it.
So now I'm into backups. I thought the E-1 would make a perfect backup with a bike bar block. No bounce at all. But my commuting run times can be relatively long 5-10 minutes easily and in the cold I wanted something that was more than a SureFire bet, I guess.
I did not consider tempermental high performance glass bulbs with 4-5 hour life times to be reliable or even very useful given the short run time and tight light focus. Hence the Nightbuster 8x.
Unfortunately I think the Nightbuster 8x will be too long and too heavy for a little rubber light block for my handlebars. I think it will bounce, nod and shake over the littlest bumps producing a strobe-effect, or maybe not...we'll see tonight.
Besides the twist-on switch is definitely a problem, the rubber seals on the back endcap are so tight the whole body would probably rotate in its rubber bar block. I would have to nail its feet to the handlebar so I could turn the switch on one-handed, after a main engine flameout.
Maybe I should glue the Buster it to the light block, switch it on all the time and await the day I can do a real life comparisons with E-2's and E-1's, and WLS-2000's against my fresnelitic, lithium-filled, halogenated Specialized Preview that is light (as in gravitationally), flat, not so cool, quickoff (so I can beat the stealers with it).
And and and it fits into my briefcase/backback pretty nicely (except when the easy-on switch goes on in my bag so the backup needs to be backed up too).
Oh, I just realized, I am now in the market for backups to my backup two.
I think I will tape an Arc-light/white whatever into a bullet hole carefully shot into my private Brain Repair Manual.
Oh, with the Nightbuster8x you can beat the stealers much quicker, if you really want to.
It is such a more useful light than the not so beautiful or so heavy CCTrek.
E-2;E-2 OH? And a light-diffuser to go. With no fresnel here may the bright spot go, and we all fall down.
StJoe
