Re: Is there a rechargeable possiblities with the
ksshoter,
buy with confidence from Jon, i did and everything went smoothly. (hi Jon...thanks again!)
as for the M3 and LOLA MN10 lamp assembly, it works 100% of the time for me with the PILA 150s batteries. no double clicking. i find that 125 lumens is quite sufficent for traffic stops and lighting up those dark places i need to see when away from my vehicle. make sure u have a smaller back up light though, unless u r going to carry the M3 on ur duty belt... if ur going to carry on ur belt, may i suggest the SOE M3 pouch. it is secured with a buckle clip, and although not fast, keeps the long M3 in place when u r running or dealing with that 'uncooperative' subject(s).
u will have to leave the M3 HOLA MN11 lamp at home since it will not light up for me (and others it seems) with the PILA 150s. double taps r definately needed on the tailcap.
another accessorie u might want is the Z58 'clickie tailcap'. very handy and allows constant on without twisting the tailcap... not as much fiddling around using fine motor skills.
stay safe!
Jon
