but then you got to pump it up and for real my gas lantern sucks to light you have to preheat it with alchol for damn near 90 seconds
Performance stats from the 'zon:I'm still a huge fan of my Coleman white gas lantern for base camps. I believe white gas carries far more lumens per pound than any battery, but I haven't verified the math. It runs great on gasoline, so if we lose the grid, we still have years of light...as long as we don't shatter the globes.
"Only" 800 lumens, but unlike a flashlight, that's 360 degrees of 800 lumens.
We'll go with the high figure since that's quoted. 800 lumens for 5 hours per 2.5 pints of fuel or 0.3125 gallons. Gasoline is about 33kWH per gallon. 10,313Wh to produce 4000 lumen-hours or about 2.58 watts per lumen.This outdoor lantern lasts up to 5 hours on high or 20 hours on low with 2.5 pints of fuel (sold separately).
800 lumens over 360 degrees, the equivalent of maybe 10 flashlights arranged in a circle. That's 4 pounds for batteries. $240 vs $1.00 worth of gas, or something to that effect. Or possibly I completely misunderstsnd the lumens measurement on lanterns.Performance stats from the 'zon:
On a mass basis ... 0.375 * 6.3 lb/gallon = 1.97 lb of gasoline. Simplistically, 4000 lumen-hours from a 100 lm/W OTF source would demand 40 watt-hours, which we could round to 4 18650 cells. A typical 18650 is around 45 grams... multiply by 4 to get 190 which is about 0.40 lb. The extra ~1.5lb could go towards additional cells or a solar charging apparatus to net considerable additional runtime.
That being said I've got a sudden hankering to retrieve dad's old Coleman lantern and see if it will fire up on gasoline.
Omnidirectional LED lanterns are a thing. BLF put their name on the LT1 which happens to be 800 lumens.800 lumens over 360 degrees, the equivalent of maybe 10 flashlights arranged in a circle. That's 4 pounds for batteries. $240 vs $1.00 worth of gas, or something to that effect. Or possibly I completely misunderstsnd the lumens measurement on lanterns.
