Is there any tape or coating that can give me more grip on my Supbeam K50 V2?
Oztorchfreak
Sydney, Australia
I am having problems turning the magnetic ring on my new Supbeam K50 V2 one handed like I do my when using my Thrunite TN31 and Fenix TK75.
The battery tube is very slippery and should have been given some aggressive knurling like other older Supbeam models.
Is there any tape or coatings that I can use on the battery tube to give me more grip.
This is the first light that I have ever considered doing this to.
Apparently there is skateboard tape that I know nothing about yet and what about the anti-slip coating that can be applied to steps?
I don't know if those coatings will adhere properly to the metal battery tube.
Anyone already been through this before? :(
CHEERS
James3
You can use grip tape/ skateboard tape, it does stick to metal very well. If you get the tape for the edge of steps it's designed to adhere to metal, you can pick it up cheap as well.
Oztorchfreak
Sydney, Australia
Yeah it looks like a bit of trial and error but this light has almost zero grip and it is needed as it has a 4 x 18650 battery tube to try and hang onto.
My Fenix TK75 with it's 4 x 18650 tube has never been a problem at all.
Nice light this K50 V2 with the USB charging but actually holding and operating it one handed is really a problem and I worry about dropping it whilst trying to turn the ring.
It looks pretty being a shiny and slippery body but some real knurling should have been applied for real world use.
I wonder how some black heat-shrink tubing would go on it.
CHEERS
Mr. Tone
Illinois
The lack of any good grip on my K50 V2 is the only real gripe I have with the light. In the Supbeam forum on CPFMarketplace I even suggested they make a new tube with knurling like the K40 for some of us to purchase as an accessory. The grip on the K40 is very nice so it is curious that they gave the K50 V2 such pathetic grip, especially because of it's size. There was someone who used some kind of tape on the K50vn thread in Vinh's subforum and there is a pic or two of it.
James3
I don't know about heat shrink tubing, but on my X10vn & X3vn (with the metal momentary button, very slippery) I just got some black sand paper sheet and some heavy duty double sided tape, works a treat. I've also used bike inner tubes stretched over lights in the past, gives it protection and a rubbery grip
Oztorchfreak
Sydney, Australia
I think the grip on the older K40 and X40 was well designed compared to this K50 V2 model.
Like you it is my main gripe and being able to purchase a better made battery tube would fix things up quite nicely.
I would buy it as an accessory too, although we should not be paying for Supbeam's inferior designs!!
CHEERS
Oztorchfreak
Sydney, Australia
I forgot all about bike tubing stretched over the body.
A mate of mine had to use it before to improve the grip of the light.
It worked a treat, just finding the right diameter tube is probably the hard part.
A clear rubbery coating would be good as the body pattern could still be seen.
Any other suggestions are really appreciated guys.
CHEERS
nbp
Wisconsin
Hockey stick tape might work. It's grippy and easily replaced and comes in a few colors.
Oztorchfreak
Sydney, Australia
Hockey stick tape.
I will have to start researching these products online now after hearing all of these good suggestions!
Thanks guys.
CHEERS
mcnair55
North Wales UK
Look out for anti slip tape that you fit to the floor of a work van for health and safety reasons,it works well even in the wet.Another easy solution is use a medium grade emery tape either super glued in position or by way of 2 pieces of heat shrink tubing.
Oztorchfreak
Sydney, Australia
I can see myself hunting around the aisles of the local big hardware store tomorrow!
How thick is the work van tape usually as I don't want the tape making the diameter of this battery tube an even bigger problem?
I am also wondering if covering the battery tube with material will make the batteries hotter by not having the battery tube exposed to your hand and also the surrounding air.
CHEERS
NutSAK
3rd stone from the Sun
Gaffer's tape is what you want. It's made of vinyl-coated cotton. It's tough, grippy, waterproof, and uses a strong adhesive that peels off without leaving residue behind.
Oztorchfreak
Sydney, Australia
I have some gaff tape in the garage as I used to do lighting and sound work on stages years ago.
I thought it might still be a bit slippery to use on my K50 V2.
There are a few different brands around that have different textures, some look flat matte and some look shiny.
It does leave some glue on various surfaces as I have used it extensively for over 30 years but the adhesive can be wiped off with a little bit of work.
I will give it a go.
CHEERS
Fireclaw18
I've used the following tapes on flashlights to increase grip:
Indoor stairway grip tape: I prefer this over gaffer's tape. I purchased a roll of indoor stairway grip tape from Office Depot. This stuff works exceptionally well for flashlight grips. It's a medium grey colored textured rubber with good glue. It provides a better grip than Gaffer's Tape and doesn't peel or get glue residue on your hands at the edges. The rubbery texture of indoor stairway grip tape feels very secure in the hand and the glue is strong enough it won't fall off. This tape also looks very nice when applied to a light... it looks like the light was manufactured with it, rather than something someone just stuck on afterwards. I used this around the body of my SC51 for a year and it worked great. The grip it provides is much better than any flashlight knurling.
Note that there are two kinds of stairway grip tape: Outdoor stairway grip tape is meant for putting on stairways for people who have shoes on. It is made of tiny bits of crushed glass embedded in the tape. It is black colored, so blends in with a black flashlight body well. However, the texture doesn't feel great on the hand (feels like sandpaper). And tiny bits of the crushed glass can come off the tape and get on your hand or into your pocket. The indoor stairway grip tape is made of rubber with no glass so doesn't have these problems.
Gaffer's Tape: This is a thin cloth tape with a fairly grippy rubbery coating. It sticks well, though you may get a bit of peeling and glue residue at the edges. It is black colored so blends in well with black flashlight bodies. I suppose you could probably stop peeling up at the edges by rubbing super-glue gel into them, but that might risk damaging the underlying anodizing if you got some on the light.
Skateboard grip tape: I haven't applied this to flashlights, but I did consider it. As far as I could tell, skateboard tape is basically the same as outdoor stairway grip tape, with the same sandpaper texture and bits of crushed glass.
Firearm grip tape: On Amazon.com you can buy grip tape designed to be applied to firearms. It is typically black in color and rubberized. The tape comes in sheets with precut sections sized for a particular weapon. You can take some of the larger pieces and cut them to size for your flashlight. I found gun grip tape to be marginally better than Gaffer's tape, but still considerably worse than indoor stairway grip tape.
Indoor stairway grip tape, Gaffer's Tape and Firearm Grip tape can all be removed from your flashlight without causing any damage to the light.
______
Since you're trying to increase the grip on a control ring on a larger flashlight another option is to simply look for a rubber band of the appropriate size. If you can find the right size rubber band to fit around the control ring, that might work better than tape. There'd be no seam and no risk of the tape peeling up.
Oztorchfreak
Sydney, Australia
Indoor stairway grip tape: I prefer this over gaffer's tape. I purchased a roll of indoor stairway grip tape from Office Depot. This stuff works exceptionally well for flashlight grips. It's a medium grey colored textured rubber with good glue. It provides a better grip than Gaffer's Tape and doesn't peel or get glue residue on your hands at the edges. The rubbery texture of indoor stairway grip tape feels very secure in the hand and the glue is strong enough it won't fall off. This tape also looks very nice when applied to a light... it looks like the light was built to use it. I used this around the body of my SC51 for a year and it worked great.
Note that there are two kinds of stairway grip tape: Outdoor stairway grip tape is meant for putting on stairways for people who have shoes on. It is made of tiny bits of crushed glass embedded in the tape. It is black colored, so blends in with a black flashlight body well. However, the texture doesn't feel great on the hand (feels like sandpaper). And tiny bits of the crushed glass can come off the tape and get on your hand or into your pocket. The indoor stairway grip tape is made of rubber with no glass so doesn't have this problem.
Gaffer's Tape: This is a thin cloth tape with a fairly grippy rubbery coating. It sticks well, though you may get a bit of peeling and glue residue at the edges. It is black colored so blends in well with black flashlight bodies. I supposed you could probably stop peeling up at the edges by rubbing super-glue gel into them, but that might risk damaging the underlying anodizing if you got some on the light.
Skateboard grip tape: I haven't applied this into flashlights, but I did consider it. As far as I could tell, skateboard tape is basically the same as outdoor stairway grip tape, with the same sandpaper texture and bits of crushed glass.
That is a big bunch of info man!
You guys have been through this loop before I can see.
I have never needed to make any light more grippy before this light came along.
I reckon a lot of guys that buy this light will need a similar solution like the ones on offer here.
As an electrician I used to dip some tools etc into a pot of liquid plastic stuff that dried and left a thick coating.
I don't know whether that would be useful on this light as I forget just how grippy it was.
Thanks.
CHEERS
inetdog
I think that the OP is trying to increase the grip on the body, not the ring. Turning the rung requires both, but I believe the ring already has texture.
Oztorchfreak
Sydney, Australia
I am trying to increase the grip on the light to hold it from dropping out of my hand.
I also need to turn the magnetic ring that is hard to do given the slippery battery tube surface and also the ring is quite tight compared to some of my other TN31 series lights.
So maybe I need the rubber band idea as well.
We should not have to be doing this exercise if Supbeam had knurled the light body properly in the first place!
CHEERS
Fireclaw18
Here's another option, I haven't tried:
A few months ago I researched Duracoat paint and ended up painting a couple flashlights with the stuff. It works ok... the color I chose still looks like paint and isn't anywhere close to as durable as anodizing. However, when I researched it, I noticed they had a clear Duracoat topcoat finish that applies a rubberized texture. No idea how well it works, but might be worth considering.
Be advised, that duracoating is not easy to do. You have to very carefully prep and clean the light before applying. And after applying you should set the light aside for 30 days to let it fully cure.
Oztorchfreak
Sydney, Australia
The problem is that when I apply pressure to turn the ring with my fingers my hand slips around the body.
That Duracoat stuff seems a bit fussy to use maybe for me.
I might try a rubber bike tube first as it should be quite grippy and easy to get from the local bike shop discarded tubes and tyres bin.
The gaff tape I just looked at seems quite shiny and slippery to me for this use.
CHEERS
Fireclaw18
CHEERS
Bicycle innner tube sounds like a good idea. Cut a section and use it as a sleeve for your light.
If that doesn't work indoor stairway grip tape definitely would work. Apply it in rings wrapped around the body of your light.
