Incidentalist
I recently purchased an iTP H01 after hearing all of the positive comments about it. Add to that the fact that I have several iTP A3s that have worked flawlessly, and I decided to give the H01 a try.
I have no complaints on the size or performance of this light as it delivers as expected. The problem comes from the poorly thought out way in which to affix the light to the headband. The fit on mine is pretty tight and herein lies the problem. It is possible, as it should be, to adjust the light up and down while in the holder, but doing so causes the body to twist while the tailcap remains stationary in the holder. Due to the design of this light, it only takes a few degrees of twisting the end cap before battery connection is lost. I find that while adjusting my light while in the holder that I almost always lose battery connection, or at best I end up changing the modes while adjusting. I even went so far as to be cautious about which way I put the light in the holder and then onto my head. I placed it at one end of the holder so that after placing it on my head and adjusting it 'up' to the level I wanted I would be twisting it in such a way that I was 'tightening' the end cap. This worked fine until I later needed to adjust the headlamp back down and , there went the battery connection. :shakehead
This is a gross oversight in the development of this light and I'm shocked that I haven't heard other reports of this. Due to this problem, I cannot recommend this light if it is to be used as a headlamp. :fail:
The silver lining is that I find the size and design of the light to be perfect for holding in my fist with the head sticking out between my fingers. That is a very comfortable and useful grip in my opinion. Unfortunately, that is not the use I had in mind when purchasing this light. YMMV
