It's alive!
bmanrkg3
After blowing the bulb in my Surefire 6P (using rechargeables), it sat lonely and unused in a drawer until one day I came across this site. After asking questions, window shopping, drooling, and window shopping some more, a few months went by and I finally pulled the trigger...
https://flic.kr/s/aHsjXYYtro
Moddoolar Ceramic Glow Triad tailcap
http://www.oveready.com/moddoolar/moddoolar-c-triad-tail-custom-ceramic-glow-white/prod_260.html
Solarforce 1x18650 body extension
http://customlites.com/Solarforce-L2-E18-1X18650-extension-tube-Sol-E18-Exttube.htm
Solarforce 18650 Dummy Cell
http://customlites.com/Solarforce-18650-dummy-cell-Sol-18650-dmmy.htm
P60/D26 Cree XML2 2.8-6v
  • Reflector Finish:Smooth Finish
  • Module Levels 2.8-6 volt:3 level with strobe
  • XML2 emitters:U2 flux coolwhite
http://customlites.com/P60-D26-Cree-XM-L2-28-6-volt-P60-CR-XML2.htmLooking for battery suggestions since currently I'm stuck using streamlight 2xCR123 (my 18650's were shot...)
vicv
Southern Ontario
I'm honestly not sure what this thread is about. Why is it in this section? Why did you buy an 18650 extension and a dummy cell? You're making it longer for no reason and the 18650 or the dummy cell will not fit in your light anyway unless you've had it bored. All you would've had to do was buy a 17670 and everything would work
bmanrkg3
I thought this was the appropriate section to share this sort of thing, and yes it has been bored. I wanted the extra length and was advised against stacking 2 18650s. The 18650 batteries I had (ultrafire) had crapped out from lack of use.
vicv
Southern Ontario
Ah just wanted a longer light. Ya stacking the cells would fry the drop in. You really should have gotten a 2 cell drop in then you could've taken advantage of the extra length
Conte
Yeah, your modual is not rated for the voltage of 2 Ii-ions. You could probably find a higher voltage Drop in, then use 2 Li-ions. It you're going to run an extension you might an well benefit from the extended runtime.
Ultrafire, go figure. * fire batteries are crap.
Meanwhile, Welcome to the club.
bmanrkg3
I'm sure I'll get to that point soon enough, just easing into it ya know? Btw, who is AW that does the batteries?
Conte
Who?
I don't know him personally, Can you be more specific?
He's trustworthy, his QC is top notch.
Wonderlite is the local distributor.
I can get you links later when I'm on my comp.
Conte
Here's the Wonderlite sales thread for AW batteries.
You can buy from AW direct, but he is in china and shipping for batteries is said to be very slow cause they do not permit them to ship out of the country via airmail. (I'm assuming you are in North America). I've bought from Wonderlite before.
You have to sign up to a different forum to use that sales thread. CFP Marketplace is separate from this section of the forum and requires another registration. I have not bothered. I just emailed the guy directly using the email listed in that thread.
Otherwise they also have a website. Nitemods.com as linked in their sig line.
vicv
Southern Ontario
That's a good cell but a bit pricey. Check out illumination supply. Look for something around 2500-3000mah. With that dropin it can't use the extra capacity anyway
Conte
Bigger is not better if your light need a lot of current to run, in which case you need a stronger IMR cell that can crank the amps but tend to have lower capacity.
In you Case with a common XML drop in, the bigger, then yeah, the better runtime.
