ernsanada
- Joined
- Apr 29, 2004
- Messages
- 2,962
I just received my JetBeam C-LE V2 from Bugout Gear CPF Special
Shipping took 3 days to Socal!
You have to be a CPF member to get this special price.
This is a gift for Christmas.
Use a Cree 7090 XR-E (Q2 bin).
My light has a ring around the beam. I thought having an OP Reflector the beam should have a more diffused ringless beam.
Fit is good.
The Type III, Hard Anodize has some spots in the finish, mostly in the battery tube knurling. Type III HA has slight mis-match in color. Other Jetbeams I received had top notch anodizing.
Uses T6061 Aircraft Grade Aluminum Alloy.
Optical lens with AR coating.
Input Voltage: 0.7-2V. AA sized battery.
Reverse Clicky, Tail Stand
PWM Circuit: Medium bright - Low bright - Maximum bright SOS - Strobe, with memory function each level (same with C-LE V1.2).
I am disapointed with CLE V2's beam output. I guess it's because Jet Beam recommends only 0.7-2V. Too bad it can't run on 14500's.
Box was smashed during shipping on the bottom. Box seal was broken.
Comes with 2 o-rings, rear rubber boot cover and lanyard.
Rear view of the Aluminum Reflector.
Inside view of the reverse clickie.
My current Jet Beam Family.
Right to Left, Jet II Q5, Jet Beam CLE V2, Jet Beam CLE, Jet I
I forgot one light.
Right to Left, Jet II Q5, Jet Beam CLE V2, Jet Beam MKII X, Jet Beam CLE, Jet I
I also took lux readings of the Jet Beam CLE V2 and Jet Beam CLE. These are the lux readings I got. I am using a Meterman LM631 Light Meter measured at 1 meter. I waited 2 minutes before taking the readings. I am using Duracell 2650mAh Nimh AA Rechargeable Batteries which were fully charged.
Jet Beam CLE V2 Duracell 2650mAh 550 lux @ 1 meter
Jet Beam CLE Duracell 2650mAh 680 lux @ 1 meter
Low readings due to recommended input voltage, 0.7-2V.
Jet Beam CLE V2 Duracell 2650mAh @ 80"
Jet Beam CLE Duracell 2650mAh @ 80"
Left, Jet Beam CLE V2 Duracell 2650mAh. Right, Jet Beam CLE Duracell 2650mAh @ 80"
Left, Jet Beam CLE V2 Duracell 2650mAh. Right, Jet Beam CLE Duracell 2650mAh @ 80" Stepped down exposure
Fit is good.
I forgot one light.
