f22shift
anywho, any measurements of what it's pulling on each mode at the battery?
i'm not sure if you missed this but any info on this?:naughty:
I did notice that JetBeam changed the specs for this light immediately prior to shipping, so it is quite possible they hadn't detected the problem in time. I would suggest that recipients of first generation Jet-I PRO lights who feel strongly about the matter contact JetBeam directly.
I guess if they do not offer a free "repair", I will not buy any more lights from JetBeam, because I have to recognize that they are not serious with their "lifetime warrenty". :thumbsdowI guess if I buy Jetbeam in the future,I will wait for the V2's.
I'm not ignoring you - it's just that I don't normally give battery current draw data. Even on my DMM's 10A port, I've noticed that actual output can be affected, calling into question the accuracy of the data.i'm not sure if you missed this but any info on this?:naughty:
That can't possibly be correct. Those currents are way too low. They should be close to 1A on high.However, I have just verified with 14500, and I get the full expect output. So I think it's fair to report my 14500 current draw results:
Lo: 2.3mA
Med: 8.4mA
Hi: 6.8mA
Sorry about that - DMM was off by a couple of decimal points on mA output scale for some reason. Re-ran on A output scale, and have re-posted the numbers in the post above.That can't possibly be correct. Those currents are way too low. They should be close to 1A on high.
Yes, but P=iV and the circuit isn't 100% efficient. If the Vf of the LED is 3.7V and you want 1A on the LED you'll need to pull about 1.1A from a battery at 4.2V because a buck-boost converter can't be more than about 80% efficient. My estimate is that the JET-I PRO has no more than 600mA on the emitter in high. (.69A*4.2V*80%/3.7V)Note however that these are only current draws taken at the battery. Emitter current draw should be close to 1A at the maximum, but that would require desoldering one of the leads to test at the emitter contacts.
Let's wait and see ...
Cup, thank you for these useful informations. :thanks:Thinking of what I might add to this concise and authoritative review is difficult, but here goes
Thanks for the support everyone - glad you are finding the review useful. .
Wow, thanks for excellent additional comments and observations. :thumbsup:Thinking of what I might add to this concise and authoritative review is difficult, but here goes. ... High output and efficient LED's (thank you, Cree) combined with the Sanyo low discharge AA's and effective (well, 2/3) boost circuits yield a really nice package, and Jetbeam has put this together well.
The poor man's low-tech integrating sphere.I especially appreciate that you use a Quickbeam style lightbox, as I do. My figures for the lights you test are very close to yours. Very usefull for me when contemplating a light purchase. Thanks!
.... I've noticed really bright lights and very strong throwers tend to be under-valued at their highest settings (i.e. the box reports less than I would expect).
