I love the Jet-III, after getting it for several weeks, my only issue remains ... the pocketclip. It needs a little more tension to be functional. That's my $0.02.
So what do you make of this one then?
Regards,
Eric
I'm almost about to place an order for one of these.
Here's my concern....
If an emergency arises and I dont have a charged 18650 on hand, can
this be run on 2 RCR123's or 2 CR123's???
Thanks for the reviews guys, very helpful!
Ray
Ray
Regards,
Eric
Citivolous, is that clip from the E1b? I tried removing the clip from the Jet-III and it was farily difficult ... I used a paracord to try to pull it out. I thought it was glued or something. How did you remove it. Has anyone else replaced the clip?
I also used some 550 cord through the clip and PULLED! Came off - and I succeeded in slicing my thumb (of the hand holding the light) pretty deeply on the clip! Darn! Suggest you wear gloves!
Good luck.
That is the clip on the new Titanium Edition. I've asked JETBeam if they have any plans of releasing a similar clip as a retrofit accessory for earlier torches, hopefully they say yes
Regards,
Eric
Another question which I posted in the Marketplace Thread but I think is better to be posted here.
What does the 'Waterproof according to IPX-8 Standard' mean?
Can I use the light under water?
rayman
Extract from a post I made in another thread:What does the 'Waterproof according to IPX-8 Standard' mean?
... the IPX8 standard is totally worthless as a way of rating the suitability of a light for underwater use. By all means test your light by dangling it on a cord at depth, but do NOT assume if it doesn’t leak that this means it will be a good light to use for diving.
Recreational divers should use a proper dive-light rated for use to at least 30m / 100ft. Anyone who uses a light which has not been specifically designed for diving is asking for trouble.
To rely on one as a back-up dive-light would be suicidal. A diver’s back-up light is by definition one which he may need to be able to rely on in an emergency, when its failure could very easily lead to his death.
