I got my Jetbeam PA40 back in November and initially was very impressed with its performance. However, after replacing the batteries for the first time I noticed that the Blinking LED warning light came on after only a few minutes use, and in use did not last very long at all. I assumed this might be a problem with the Eneloop batteries so ordered a new set of the Eneloop XX 2600mah. These however performed in exactly the same way, with the battery indicator coming on after a few minutes. In addition to this, I noticed the battery indicator flickered when you moved the torch about. Giving the torch a little shake whilst pointing down causes the indicator light to light up solid red (a state that is not mentioned in the literature).
There is a rattle and you can feel the battery housing moving around inside.
I then tried it with 2 sets of Panasonic Pro Power batteries, with the same results. The light was returned to Heinnies Haynes where I bought it from who in turn sent it to Jetbeam UK. The light arrived back a few days later stating they could not find a fault and blamed poor battery condition. I popped some new batteries in and started a stopwatch; Four minutes later the indicator comes on. Little shake, LED changes to solid red.
Has anyone else experienced anything like this? I don’t know what to do with it as I’ve pretty much lost faith in this piece of equipment.
Very disappointed as this was my 40th Birthday present.
Would appreciate any advice,
Thanks,
Patrick
Thanks,
Patrick
