Jetbeam RRT01vn - The Best EDC R
Wurkkos
vinhnguyen54
CPFBA
The Keeppower 1200mAh 18350 flat top I tried doesn't work but the Vapcell 1100mAh 18350 flat top works fine. Don't think the positive protrudes enough on the Keeppower to make contact.
I got 1200mah 18350 that would work ;-)
xevious
Hoboken, NJ
The bottom of the pill looks to have a cover plate with physical reverse polarity protection (raised plastic ring) just like the old RRT-01.
Most of my flat-top Aspire 18350s do work with the new RRT-01, but at least one does not.
Thanks. I just took a small 1mm x 5mm magnet and put it on top of the cell -- that worked. The raised plastic ring seems to help keep the magnet from sliding around.
vinhnguyen54
CPFBA
Nice! For a general EDC, this covers just about everything one could possibly need.
She hates spots so her lens is diffused. Man! I love throw and she prefer floods. She said there is nothing interesting far away to see. All the important thing is here in front of her. hahah
HarleyXJGuy
Hi everyone. Long time fan and owner of VDogs lights and I have a question.
How much difference between this light with the W1 LED and one of the Pocket Searchlights? Think it is a D25.
Sos24
One of the biggest differences between the RRT01 and the D25c is the UI. The RRT01 is a rotary ring light that starts low and goes to the highest by rotating ring with incremental brightness changes. Whereas, the D25c is a reverse tail clicky with 3 brightness settings plus multiple strobe/flash modes.
HarleyXJGuy
Thanks for the quick reply!
My first good light was a stock V11R. Great light that is just missing the VMoney touch.
EDC lights and light with throw are my favorite but I was wondering and wasn’t clear enough in my first post.
How much difference will I notice in the output between these two lights? The D25 is a good bit more powerful?
dotCPF
New Angleland
D25Cvn has VN4, which has multiple banks of available UIs. Read here: https://skylumen.com/pages/drivervn-drivervnx-programmable-circuits
the D25Cvn has higher output with White 1, about 200 lumens, and has about 8kcd more intensity. The difference here is noticeable, but I wouldn't say it's HUGE, especially given both of their sizes and purposes. One of the biggest differences, to me, besides UI, is the RRT can take 18350 cells, which are much better for an EDC IMO.
vinhnguyen54
CPFBA
All of new arrived batch is also sold out. Anything you ordered after this message is on the next batch in 2 weeks. Thanks
Fireclaw18
Vapcell is now selling high drain 800 mAh 16340 cells.
As such the gap between 16340 and 1100 mAh 18350 is not as big as it used to be.
vinhnguyen54
CPFBA
1200mAh 18350 is hte way to go! Actually I need to test one to see if they are really 1200mah. Sounds kinds steep!!!
Fireclaw18
I recall the first 18350 cells out with the new chemistry were Aspire brand. Initially, they were marked as having 1200 mAh. But after independent testing showed they only produced 1100 mAh, the manufacturer changed the label on the battery to 1100.
I suspect the currently available 1200 mAh 18350s from other manufacturers have the same internal chemistry and are probably closer to 1100 mAh, and I would be interested in seeing your test result.
vinhnguyen54
CPFBA
1100 would be impressive already
InvisibleFrodo
Keeppower lists them with a typical capacity of 1150 mah and a minimum capacity of 1100 mah. So it would stand to reason the best cells in the bunch will have capacities of 1200 mah if the typical (average) is 1150 mah.
Tejasandre
SA, TX, UsA
Beam shots. RRTO1 & HDS , both Nicha 219b sw45.
RRT-01
HDS
HDS left, RRT right
Low beam
Side by side
