Jetbeam RRT01vn - The Best EDC R
Wurkkos
LogansRun
Well-known member
Thanks for posting the beam shots!
I still have the first gen JetBeam RRT-0 with the magnetic control ring function... Although the lumen output is only about 250 lumens and only fits an RCR123 / 16340, the ring function and overall size is still perfect. My original still sits on my kitchen countertop as a general purpose, very reachable light.
I'm in for one, order placed. I'm looking forward to having an upgraded version. Thanks Vinh for offering these!
Tejasandre
Well-known member
SA, TX, UsA
If you mean me, glad they were helpful
ma tumba
Well-known member
Russia
I wonder if the carclo optics in the triple version is user swappable?
Отправлено с моего iPhone используя Tapatalk
ma tumba
Well-known member
Russia
Also is the stock version compatible with 18350, or 16340 only? What does exactly mean the statement on skylumen that the light works off an AA?
And finally, how deep the mcpcb can sit in the mule configuration. I would like to limit the mule beam width to, say, 90deg, is it reasonable?
id30209
Well-known member
Croatia, EU
Vinh, how hard it would be to rework the bottom of the body, edge shoulder where negative spring is placed?
If that shoulder is removed and spring placed lower then 18350 protected can be used for more juice and not overdischarging the cell....
Sent from Tapatalk
vinhnguyen54
Well-known member
CPFBA
Also is the stock version compatible with 18350, or 16340 only? Use 18350. Forget 16340 ;-)
What does exactly mean the statement on skylumen that the light works off an AA? I copy and paste factory specs. Not sure why that part is in there. AA will not work.
And finally, how deep the mcpcb can sit in the mule configuration. Currently LED sit on 3 layer of copper MCPCB. We can eliminate 2 later so the LED would fit down lower for a more narrow spill beam width.
Derek Dean
Well-known member
Monterey, CA
Howdy, I'd sure like to get one of these, if possible with the 219B 4500, or something similar (hi CRI with slightly warm tint, not green or blue). What is the next step to order?
Derek Dean
Well-known member
Monterey, CA
Just got my RRT01vn with triple 219B 4500 LEDs with the diffused optic. Oh my, I've NEVER received a light that actually had the perfect beam and perfect tint, until getting this light. A broad, smooth, even beam with just a hint of a hot spot. Perfect. Thank you so much!
gottawearshades
Well-known member
Two questions:
Do you still have these on hand to order now, and do you have trits to install (ideally green)?
Planning on the SST-20 4000k option.
Thanks.
