A
aau007
- Joined
- Sep 12, 2010
- Messages
- 441
So I used a watt meter to test the light. I used a hot off the charger Ultrafire 16340 that started off at 4.18v. When blasting it to max, the current draw was 1.8A at 3.6v. That's almost 6.5W draw at the battery. Then as the loaded voltage dropped to 3.3v, the current draw was about 1.3A, that's only 4.3W at the battery. At 3.1v, 0.9A, at 3.0v, 0.85A. Then at about 2.45v, the light went into rapid flashing and shut down. The supposedly protected Ultrafire 16340 did not cut off voltage soon enough before the light's rapid flashing. I wish the battery would cutoff at no less than 2.5v though. The bright side is, I manage to get over 700mah out of the battery before it dropped below 3.0v, pretty much driving the battery starting at 1.8A all the way down to 0.85A at 3.0v.
Does that mean this light is direct drive?
I am going to try to hook up a 18650 later to see.
