Jetflame/Torch with simple bic as cartridge
diamondback
Hi all,
I've been searching for a whil for a jetflame lighter where you can use a normal lighter(bic, cricket,... standard size) as a cartridge. I think this have the best of both worlds, but I can't find a nice one. The only one I found is this, but not really what I'm looking for: http://www.hobbico.com/tools/hcar0755.html
hope someone knows a brand that makes them
The one you found is the only one I've ever seen. As far as I know, they drain gas through the fill-hole in the bottom of the lighter; the burner at the top of the lighter is calibrated to release gas too slowly to produce a stable blue flame.
EDIT: Maybe I mis-read the link you posted. Is this more what you're looking for? http://www.thinkgeek.com/gadgets/tools/8868
Getting your butane packaged inside a plastic lighter is horribly inefficient, btw. The fuel inside a Bic lighter would get used up by a torch in a couple minutes. Buying the big canisters of butane fuel is both more economical and better for the environment.
i tried few of them gas runs out faster that you can finish what you started, and they don't live long, plus flame would not stay constant, after 1 min or so it was jumping, i don't even remember brands, all crap.
what is not crap are the ones that have their own gas tank, but those can be expensive, another thing that i tried and still use, is radio shack butane soldering iron besides soldering tip it also has torch tip, and it fits a lot more gas than bic lighter, it also smaller than all of those torches.
most if not all gas soldering irons have torch tips, radio shack one cost $20, i also had more expensive and better quality iron pyropen made by Weller. but it broke, cheap one from radio shack still works, for a year already,
no, those lighters are disposable, they don't have fill hole at the bottom.
few that i had used normal top valve but had their own piezo igniters instead of tuning the flint wheel
I'm searching for something that has more the look and feel of a normal butane torch. Guess most of them have their own butane tank
