Joinable poles
PEU
Buenos Aires / Argentina (I like ribs)
Im pretty sure these are not turned on a lathe but somehow pressed:
Do you guys know how to make them? I need to make 3x 2mt (about 7ft) tall poles using this method for easy carry. Aluminium tubes are easy to find in many sizes here.
Thanks!
Pablo
The rod in the hollow pole is the way it is commonly done. A very slight taper near the ends of the pin will help in getting them started. You do not want too tight a fit. Galling can be a real bear when you are trying to force them together or take them apart.
Make the rod several times longer than the diameter of the hole.
Daniel
