JSO123,
Looks like Carpe Diem might hook you up with a USL, but if not, just shoot me a PM, because the short answer is "yes", I can probably make you a USL. I can't promise anything right now, and I'm pretty much just focused on finishing the outstanding orders, but I doubt it will be a problem.
Everyone,
Charging instructions:
I suggest a C/2 charge. For the Titanium 1800 cells, that means 0.9 amps charge rate. For the Triton, make sure the cell type is NiMH, set the rate to .9 and have no time out, but set the max charge delivered to 2100 mAh, and set the delta V sensitivity to 3 or 4 mV/cell. Also, feel free to set the top off charge rate to 200 mA.
For the Hitec, make sure you're in NiMH mode, and set the rate to .6 amps or somewhat less (be sure to read the right scale-ring on the dial). Then just push the start button. Be sure to monitor the charge towards the end, because the Hitec has been known to miss the end of cycle peak. Or it has done so to me, anyway.
However, MOST IMPORTANT: be sure to INSERT THE BANANA PLUGS INTO THE CHARGER FIRST, before attaching the small black molex connector to the charging pigtail on the light. The reason is because once you connect the charging cable to the pigtail, it is directly connected to the battery pack + and -, and if those two banana plugs touch each other you will short out the pack outputs, putting many amps through the charging cable and molex micro connectors. This will surely fry the small connectors, which are only rated for 3 or 4 amps or something. So, if those banana plugs are already inserted into your charger, then there's no chance of them accidentally touching each other.
Also, I like to stand the USL on its head, grabbing the molex shell on the pigtail with one hand, and it's mating molex shell on the charging cable in the other. Note that there is a locking bar which keeps them mated, and you will need to press on the lever to release the lock before separating them.
I think that covers the charging instructions, but if anyone has any questions, please feel free to ask!
