JTICE - 4Sevens LED Tint Comparison Review (white, neutral, warm)
Jack Reacher
Melbourne Australia
Thank you for that link John. :)
As a flashlight newbie, it was of great interest to me to see the side-by-side comparison with a specific reference to the terms as applied to each type of output.
Why is it that we can't then choose the colour temperature that we personally prefer when we buy a "brand name" product — say a Fenix TK40 — which sells for nearly $200. It seems colour temperature is a pretty important issue for most folks (judging by the sheer number of time it's mentioned on CPF).
Why doesn't Fenix (say) offer a choice of either a cool, neutral, or warm tint emitter for a light that costs so much? Why are we effectively forced into accepting whatever tint comes randomly (apparently) out of the bin in China?
Or am I simply asking for the technically (and/or economically) impossible?
—Cheers, Jack.
MichaelW
USA
When did 4Sevens ever make a Neutral White mini?
There was a run around new years where the xp-g was substituted for an xp-e Q3 5A
There will probably be a new run with an xp-g R4 4500K
jtice
West Virginia
Some lights, especially from 4Sevens are going to start being offered with color options actually.
Specifically white, neutral and warm.
Making 3 versions of a light instead of just one will always drive up costs, so i assume thats why its not done alot of the time.
~John
phantom23
http://jtice.com/review/lights/led_tints
~John
"The following photos are a bit exaggerated, but they will give you an idea for the differences in the led tints.
The neutral tint shows a bit purple in these photos, thats not the case in real life."
In real life white looks like 'Neutral', neutral looks like 'Warm' and warm is even warmer (orange/red, like incandescent light).
Unforgiven
Administrator
Missouri, U.S.A.
Nice download speed phantom23 but you'll need to resize the sig image though. It's too big. ;)
Nice reviews John. Good to see you posting too. :thumbsup:
UnknownVT
Yes, those were my initial thoughts too.
But since our eyes adapt to different light conditions and do not necessarily see the same way as a camera - three beams on a single photo has some validity as a comparison - since all the beams get the same white balance treatment - so the "ratio" (as if it were) of differences should be about the same.
I note looking at the EXIF metadata that jtice is using a Canon PowerShot G9 with white balance set at "Custom 2" -
so I am hazarding a guess that jtice has deliberately set the white balance for these shots - perhaps showing the Neutral White as "neutral"/gray as possible - hence the extra blueness of the Cool White and less amber/red of the Warm White almost tending a little toward gray.
Whereas using the Fixed Daylight White Balance (sun icon) would show the photos closer to the way phantom23 described.
John/jtice -
Can you please tell us what your Custom 2 White Balance is set to?
Thanks.
jtice
West Virginia
I am pretty sure that I set the white balance with all three lights shining on the white wall, and set it to that.
That way it should have been set to a happy medium between all the lights, giving the best chance of showing the difference between them.
I played around with a few other settings, none looked true to real light really.
Each will lean one way or another.
~John
UnknownVT
John,
Not intending any disparagement -
but pointing the camera at a white wall and setting a manual white balance -
is very dependent on the lighting -
ie: whatever was lighting the white wall at the time
eg: it could have been -
regular tungsten household lighting,
fluorescent lighting,
or some mixed lighting...
daylight through a window,
direct noon-daylight (including the sun -
unlikely unless you have a white wall outside....)
- so this is rather a bit of a big variable.
My guess is that your overall lighting for the white wall was about 4100K
since that probably would be the average color temperature of the three lights -
this is probably the equivalent of using the AWB (Auto White Balance) on your camera
- hence the "neutral"/gray looking Neutral White.
It may seem less technical to just set the Fixed Daylight White Balance (sun symbol) - but that is the equivalent to manually setting a white balance on a sheet of white paper out in the noon-day sun - a reference that most of us understand - eg: hence phantom23's response.....
jtice
West Virginia
Actually, there was very little ambient light at all, I did that on purpose so it wouldnt fact that in.
but you do have a valid point, I dont have the lights anymore, but next time i will try many different settings, and see which ones look closest to real life.
Again, thats why i mentioned that my photos were only to see the amount of difference between then, but the actual colors themselves.
~John
UnknownVT
John,
Sorry, I had just edited my post to make it clearer.
