Cool find, never seen one of these... Looks like it's a 150w short arc...
http://itlasers.co.il/pdf/SETBEAM.pdf SET BEAM
SET BEAM mounted on 7.62mm MAG
Long-Range High-Intensity Xenon Searchlight
SET BEAM is a compact searchlight that emits a highpower,
focused long-range beam from a lightweight,
ruggedized enclosure. SET BEAM’s condensing lens
design prevents the distracting “side lobe” (scattered-light)
eect typical of standard reector-based
projectors, rendering a higher quality, longer range
beam. The operator can opt for a continuous zoom
(narrow-wide-narrow) that can “jump” to a pre-set SPOT
position by merely pressing a button.
SET BEAM enables the detection of man-size objects at
ranges exceeding 1 km, and can be used for long-range
illumination, search and target acquisition as well as for
specic pin-point target designation. The system can be
hand-held, heavy weapon-mounted or vehicle-mounted,
according to operational needs.
Fault-free, reliable operation under adverse
environmental conditions.
Ideal for non-mobilized & mobilized forces, infantry,
armoured units, marine and airborne platforms, and
for border security and peacekeeping scenarios.
FLASH and SPOT modes
Continuous beam (narrow-wide-narrow)
24V DC Power Supply Unit
Fully compliant with US MIL-STD-810
Optional remote control
Optional lter for Visible or IR beam
*FLASH and SPOT modes
*Continuous beam (narrow-wide-narrow)
*24V DC Power Supply Unit
*Fully compliant with US MIL-STD-810
*Optional remote control
*Optional lter for Visible or IR beam
Technical Characteristics
Optical
Intensity
900 lux (min) at 40 m (narrow beam)
Beam Divergence
1.0° to 2.5° + SPOT position
Light Source
150 W short-arc Xenon lamp
IR Filter (Optional)
Type
Colored lter glass
Wavelength
830 nm cut-on
Electrical
Power source
24V DC standard; high-eciency power switching regulator type
Current
Consumption
Flashing Rate
7 ashes/sec
Thermal Protection
Power cut-o when Power Supply Unit temperature exceeds +63°C
Physical
Dimensions (LxHxW)
Searchlight
320 x 135 x 92 mm
Power Supply
160 x 110 x 230 mm
Remote Control Unit
119 x 32 x 76 mm
Weight
Searchlight
3.2 kg
Power Supply
3.5 kg
Remote Control Unit
0.5 kg
Environmental
Complies with MIL-STD-810
The manufacturer has a policy of continuous improvements and reserves the right to make changes without prior notice l 01/08
ITL Optronics Ltd.
11 Granit St.
P.O. Box 10168
Petach Tikva 49002 Israel
