I happen to be an Electrical Engineer, so the parameters/manual actually make sense, but getting started is always a little confusing.
I am an electrical engineer.
So is my father, so is my wife.
My son is a software engineer, but he showed my how to calculate the transient plus steady state on an AC line.
I am in a state of confusion with every new thing that comes along.
The important thing is to start documenting with schematics and lists, as you did.
Then even a pea brain, like mine, can understand the situation.
I too have a small knee mill, a Rockwell 21-100 circa 1962.
I put this 6 inch wheel on:
http://www.use-enco.com/CGI/INSRIT?PARTPG=INLMKD&PMPXNO=4824784&PMAKA=240-0678
With this rotating handle:
http://www.use-enco.com/CGI/INSRIT?PMAKA=319-7677
The crank handle on a Bridgeport may be warranted with a very heavy knee, but the 6" wheel is much faster on a little 21-100.
Unless I am wearing gloves, I need the rotating handles on the wheels.
The wheel to be adapted needs a bore with a keyway.
I could cut the keyway with a hacksaw or find a bore with a keyway and use that.
I found a bore with keyway from an old handle with the wings smashed off, and turned it down on the lathe.
I bored out the wheel, and drilled and tapped a set screw into the wheel, and put the old bore inside the wheel and the incremented dial.
What does it all mean?
1) The crank handle for raising the knee needed to be a smaller.
2) The cross feed wheel needed to get larger.
3) They both needed rotating handles.
