Well, I finally got the DRO installed in my mill. I bought the kit from Shars only about 12 months ago, so I guess it was time to finally install it
Many, many thanks to Daniel (gadget_lover) for this advice, and photos - much appreciated :bow:
Here is my mill prior to getting started a couple of days ago:
The kit I got from Shars about a year ago !!!
The most confidence-inspiring part of the kit :devil:
Photos from Daniel ready for reference. As you will see, although my install was slightly different in how I attached the scales, it follows Daniel's advice:
I first had to remove I few things, like my E-stop (which I still have to relocate):
Like Daniel suggested you really need to get the table position on all extremes to see what could be a problem or not:
So I found I had to move my 220-V OFF/ON switch as it would interfere with the "Y" scale:
I also had to move the oil pump a little to make room for a bracket for the "Z" scale (before and after pictures):
Lots of "Z" travel possible - about 20 inches, and to within less than 2 inches from the spindle:
Of course in a case of poetic justice I used the mill to mill some parts as I went along:
Used transfer punches everywhere to locate where to drill the holes:
In this case of the "Z" scale the scale itself is fixed, while the measuring head is the one that moves:
Also used my trusty old and cheap saw to trim the pieces (now easier to use with a hydraulic piston!):
And used my lathe to trim/adjust spacers:
Since the column gets thinner on top, there is a large gap that needed spacers:
Almost there:
Then used my trusty Noga/Interapid setup to check/adjust alignment. This was both good and bad. The problem is that all of the pieces have flex and are not perfectly flat, so you can only adjust things part of the way. I decided to also use the "resting" place of the scale and reader and ended up setting/adjusting everything up to minimize/eliminate as much as possible any binding:
Here the "Z" scale is done. I am testing it with the display:
I then made brackets for the "Y" scale. Here the reader is stationary and the scale moves:
Important to have it "out" enough so that it clears the main column:
I got the base for the reader aligned for initial setup using a couple of Starrett pieces:
Final assembly (note use of the thin spacers that come with the kit - imperative for proper alignment and in order to minimize binding):
Here the "Z" scale is done, and I am testing it with the display:
The "X" scale was the easiest since I don't ever use the table stops (famous last words!), so the scale was setup directly to the table, and the reader is fixed to the X-Y platform which moves with the Y axis:
Testing with the reader:
I mounted the display in the same place as Daniel. Here I am using my extremely quiet (sounds like an electric dill), light-duty air drill, which arrived when I was doing the "X" scale - I wish I had it earlier when I started the project:
Overall view (not quite done cleaning everything yet):
View with everything cleaned. I still have to bolt the cover for the "X" scale, and relocate the E-stop, but the bulk of the work is done :thumbsup:
EDIT: Here are the photos of the "X" scale cover and the magnet I used to make the E-stop a movable setup.
Here I am cutting the cover to allow easy access to the two gib screws that hold the xy table stationary in the x direction:
I also cut the top side of the cover to clear the table:
Here you can see better how the lower cut helps clear the table screw stops:
And finally, a small bead of silicone to make sure I don't get accumulated debris in between the cover and the table:
Here is my E-stop with a powerful hard-drive magnet. Once in place, it does not move while in use - not even a little bit. It takes a lot of force to move it afterwards to a new location:
With some double sticky tape I added a tape measure to the top of the scale cover for reference (marking the center of the table as well):
Will
