Ray_of_Light
I received today the new Sunwayman M10A (AA) and M10R (CR123), I wanted to post my first impressions.
I am after ring controlled lights, as I consider the best interface to control the brightness of a flashlight, so I am trying to acquire all the possible models available.
The M10A is, in my opinion, a masterpiece of a flashlight, if you exclude the clips from the evaluation. Thick and uniform anodise, properly designed reflector for an XP-G LED (no doughnut hole in the beam), LED well centered. The selection of levels is properly done this time: Low is 3 mA, Med is 350 mA and High is 2 Amp from the battery. The converter is of very high quality, at the par of the one in the JetBeams. I tested the flashlight with Ni-MH, alkaline and LiFeS battery, and it works fine with all three chemistries. The operation of the controlling ring is absolutely perfect. In my opinion, the new M10A could be easily declared the best commercial AA flashlight of 2010.
The M10R R5 is replacing the old M10 model with the XR-E R2. The biggest gripe with the old M10 was the improperly chosen brightness levels. Well, in the new M10R the levels are selected with attention and I am satisfied of the consistency.
On the negative side of things, other than the clip, which is the standard clip-on from Sunway, there is to note the absolute incompatibility of the M10R with RCR123. While with the old R2 model a 4.2 V Li-Ion was producing an inconsistent operation of the controlling ring, in the new R5 model will immediately blow up the output MOSFET.
As I will use more the two new M10 flashlights, I will post more findings. For the moment I just wanted to share my sense of approval for those lights.
Regards
Anthony
Regards
Anthony
